Does this cam timing look on?
Old May 23, 2006 | 06:27 PM
turbotime's Avatar
Default Does this cam timing look on?
Ok I got the golden eagle cam gears and i drove the car and it felt a little boggy like some sort of timing was off. I set TDC to the dotted lines on the GE gears, but also i didint set the ignition timing yet. Just want to make sure this is set correctly at tdc cause i dont wanna bend valves:
Look right? I was told to align it to the dotted lines (not the solid)
Old May 23, 2006 | 07:16 PM
turbotime's Avatar
Old May 23, 2006 | 07:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: Does this cam timing look on? (itsJDMyo)
It is on the white TDC mark. The other set of 3 marks on the left are the timing marks and the center one is RED. Your cam timing looks dead on.
Old May 23, 2006 | 07:52 PM
turbotime's Avatar
awesome thanks muckman, is the dotted line the correct line? cause i noticed the solid line is awful close
D3vin
Jan 1, 2011 06:42 PM
tinyscivic
Mar 9, 2010 09:03 PM
Mugencrxsir1
Jan 15, 2007 10:41 AM
v.i.gsr
Nov 16, 2005 02:06 PM
ludewithanh22
Oct 1, 2004 09:20 AM
