do you see anything wrong with this?
Old May 19, 2010 | 06:46 AM
golf-mk3's Avatar
Default do you see anything wrong with this?
those r my eagle rods with arp bolts. when i hand thighten the bolts the lower part is not flush wit the rod. i didnt try torquing them with any tools yet im scared i will break something.
Old May 19, 2010 | 07:01 AM
kyden's Avatar
Default Re: do you see anything wrong with this?
it looks like your caps are on backwards
Old May 19, 2010 | 09:11 AM
golf-mk3's Avatar
anymore input i fliped them around same thing
Old May 19, 2010 | 09:22 AM
30psi_gst's Avatar
That part sticking out of the cap slides into the rod. Tq down to spec and should be fine. My DSMs i did were 60 ft lbs i believe.
Old May 19, 2010 | 12:26 PM
E85B18's Avatar
x2. This is normal, they slide into the rod. 60 ft lbs is too much depending on the rod. Which rods/bolts are these? Look up the torque specs on ARPs site:
http://www.eaglerod.com/mosmodule/bolt_torque.html
My B18 calls for 43ft lbs
Old May 19, 2010 | 12:33 PM
Scott_Tucker's Avatar
Are those dowel pins too long? Are they the original ones?
Old May 19, 2010 | 12:46 PM
96electronH's Avatar
if the dowel pins are org and the caps are on right when u tighten them down it will draw them in
Old May 19, 2010 | 02:51 PM
SD_Lurker's Avatar
HT White Ops
There is nothing wrong with the rods. Apply a little pressure and it will seat the dowels in the rod..
Old May 19, 2010 | 03:16 PM
golf-mk3's Avatar
yeh that i thought was going on, better be safe than sorry. thanks for all the input
Old May 19, 2010 | 03:54 PM
Project_EK's Avatar
Nothing is wrong bro...tq them down to spec, and u'll be good to go..
Old May 19, 2010 | 04:00 PM
SD_Lurker's Avatar
HT White Ops
Your absolutely right, its better to be safe then sorry..
Old May 19, 2010 | 05:37 PM
TylerB's Avatar
You may already know, but make sure the knotch on the rod and the cap are facing the same direction when you install them.
Old May 19, 2010 | 08:32 PM
95skunkedgsr's Avatar
they should have the bearing size etched into the caps and rods look at them close make sure you got em all liined up
Old May 21, 2010 | 09:18 PM
golf-mk3's Avatar
thanks for all the info guys but i never built a motor before so im gona give it to a professional to put it all together of me.
Old May 21, 2010 | 11:42 PM
I think thats a smart choice.
Old May 22, 2010 | 05:32 AM
96 GSR-T's Avatar
lol x2.... dowels can be very tricky
Old May 22, 2010 | 03:07 PM
rat city rex's Avatar
since you have never built a moter. Check out this
http://articles.evans-tuning.com/200...e-build-video/
LSVtechnologytur...
Jul 14, 2008 07:39 AM
EK FLY
Dec 31, 2004 06:18 AM
Nextelbuddy
Feb 12, 2004 12:39 PM
b20ek
Jun 15, 2003 07:02 PM
S13 slide
Jan 8, 2002 09:29 AM
