Do you guys know the answer?????
Old May 5, 2003 | 03:37 PM
TeStUdO's Avatar
Default Do you guys know the answer?????
https://honda-tech.com/zerothread?id=496519 heres the link any help is appreciated
Old May 5, 2003 | 03:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Do you guys know the answer????? (00si5)
There are so much variable to figure out CR. Head, head gasket thickness, pistons etc...
need more info..
art
Old May 5, 2003 | 04:13 PM
TeStUdO's Avatar
Default Re: Do you guys know the answer????? (Arturbo)
well im using a gsr head, stock head gasket. the pistons are coming out of an ls block and head with stock head gasket. 9.5:1 comp on the ls. what would it yield in my gsr?? any better?
Old May 5, 2003 | 04:42 PM
intekragsr's Avatar
http://www.c-speedracing.com
look for their compression calculator.
Old May 5, 2003 | 04:46 PM
TeStUdO's Avatar
thanks, i tried that earlier and it wasnt working. it worked this time though. but it still says its 9.5:1 in a gsr, which doesnt seem right to me because i figured they would have a different dome height
Old May 5, 2003 | 05:13 PM
ekb18c's Avatar
It's going to be higher then 9.5:1 because of the combustion chambers of the gsr head. How high? My guess is just as good as yours.
But I'm going to go out on a limb here and estimate about 10:1 + or - .3
ls_bitik
Aug 9, 2007 08:22 AM
brookliner7
Aug 30, 2005 05:27 PM
InfamousRS
May 31, 2002 03:27 PM
