do u use a gasket between the turbo and downpipe?
Old Nov 22, 2005 | 08:55 AM
ssrcx94's Avatar
Default do u use a gasket between the turbo and downpipe?
i've looked to see if anyone sells a gasket but no luck.
Old Nov 22, 2005 | 08:57 AM
Infinite Auto's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (ssrcx94)
Just get Copper RVT gasket maker.....works like a charm, any autozone/pepboys etc. has it
Old Nov 22, 2005 | 09:00 AM
ssrcx94's Avatar
thanks
Old Nov 22, 2005 | 09:20 AM
drumking15's Avatar
or be a cool kid and run vbands
Old Nov 22, 2005 | 10:32 AM
dpetro1's Avatar
Default Re: (drumking15)
i just bolted it to the turbo, no gasket, no sealant, no problems here.
Old Nov 22, 2005 | 12:47 PM
Steve91's Avatar
I was told none was needed. No leaks so far on my setup.
Old Nov 22, 2005 | 12:58 PM
RyanEJ8's Avatar
Not necessary.
Old Nov 22, 2005 | 01:03 PM
11psiTurboSI's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Not necessary.</TD></TR></TABLE>
Old Nov 22, 2005 | 01:23 PM
porsche997dc2's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (11psiTurboSI)
I'm not using one. It's not leaking yet.
Old Nov 22, 2005 | 04:09 PM
yee SERIOUS's Avatar
i use to. it got burnt. lol i used the gasket material that comes in a big sheet from napa. it was like 30 bucks
Old Nov 23, 2005 | 03:00 AM
D@nnY's Avatar
Old Nov 23, 2005 | 07:23 AM
drumking15's Avatar
if you that **** about it...homedepot sells some copper sheeting....use a hammer to make an outline...then using a screwdriver...cutout the sheet...the stuff is really soft but can take the high temps
Old Nov 23, 2005 | 07:40 AM
beerbongskickass's Avatar
It made my intercooler kinda dirty, so I started using a gasket.
Old Nov 23, 2005 | 08:15 AM
VI Boost's Avatar
like said the previous 3 times before me
Old Dec 18, 2005 | 07:08 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: do u use a gasket between the turbo and downpipe? (VI Boost)
how big of a gap will the exhaust leak out of? Is .02 thou to big of a gap?
I can just stick a .02 feeler gauge in one spot exteremly snug, nothing else on any other parts of the snail
Old Dec 18, 2005 | 08:11 AM
turbotime's Avatar
no gasket needed
Old Dec 18, 2005 | 09:21 AM
PINKS's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (905EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 905EF8 &raquo;</TD></TR><TR><TD CLASS="quote">how big of a gap will the exhaust leak out of? Is .02 thou to big of a gap?
I can just stick a .02 feeler gauge in one spot exteremly snug, nothing else on any other parts of the snail</TD></TR></TABLE>
Old Dec 18, 2005 | 09:23 AM
turbotime's Avatar
do you hear it hissing? then its leaking.
Old Dec 18, 2005 | 09:41 AM
rudebwoy's Avatar
I dont use one, but was thinking that it would probably lose boost from leak at the wastegate hole if its not sealed correct, so I might get one from here, http://www.forcedfab.com
Old Dec 18, 2005 | 09:43 AM
john d
Guest
Posts: n/a
Old Dec 18, 2005 | 09:44 AM
rsintegra's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (john d)
flange then?
Old Dec 18, 2005 | 10:05 AM
livinlow's Avatar
Default Re: do u use a gasket between the turbo and downpipe? (rsintegra)
I needed one because I'm only using 4 out of 5 bolts and it was leaking a little so I got my 5 bolt dp gasket from http://www.roadraceengineering.com.
Honda Motorcycles
11
Jul 2, 2007 03:19 AM
Rob97'SH
Jun 14, 2007 06:07 AM
btech
Aug 13, 2006 10:25 PM
95dc2teg
Jul 17, 2006 01:26 PM
4-banging
Mar 15, 2004 12:03 PM
