Do i need a fuel pressure regulator??
Old Jul 21, 2006 | 12:22 AM
95dc2teg's Avatar
Default Do i need a fuel pressure regulator??
I have a 95 Integra GS-R with the following setup:
Stock b18c1 motor
Garret t3/t4 turbo .57 trim
Tial 38mm wastegate with 7psi (or 5psi whichever my set up is good for)
345cc Prelude si injectors with resistor box
Chipped p72 (will be tuned with crome)
Hks ssrq blow off valve
Rev hard log manifold w/rev hard down pipe
Getting a walbro 255 fuel pump
custom ic piping w/precision intercooler
With the injectors and the amount of boost im running (7psi) do I need a FPR? if so what is a good reliable brand to get?
komat's Avatar
Default Re: Do i need a fuel pressure regulator?? (95dc2teg)
no
im still using stock
Old Jul 21, 2006 | 12:27 AM
b00sted_hatch's Avatar
Little Hercules
Default Re: Do i need a fuel pressure regulator?? (komat)
No.. Your tuner will adjust your duty cycle of your injectors.. Simple as that.. I would also save my money on that Walbro Fuel Pump and put it towards tuning, because you won't need it. Just my opinion.
Old Jul 21, 2006 | 12:34 AM
95dc2teg's Avatar
Default Re: Do i need a fuel pressure regulator?? (b00sted_hatch)
So the stock fuel pump will be sufice?
komat's Avatar
no
unless you dont plan to make over 200 or something like that
Old Jul 21, 2006 | 12:50 AM
Little Hercules
I made 249/192 on my stock pump with RC 440's, tuned on Chrome Pro @ 7psi on a 01 ITR..
Hmm... LESS THEN 200whp? From my experiance it worked, and worked great too..
Old Jul 21, 2006 | 01:47 AM
paulzy's Avatar
http://www.hondata.com/techfuelpump.html
Old Jul 21, 2006 | 07:31 AM
95dc2teg's Avatar
Default Re: (paul vang)
so stock fuel pump would be ok with 345cc injectors and 7lbs for a little while?
Modified by 95dc2teg at 12:25 PM 7/21/2006
Old Jul 21, 2006 | 11:26 AM
95dc2teg's Avatar
Default Re: (95dc2teg)
bump
matsgsr
Feb 29, 2008 07:22 AM
allicedout
Apr 22, 2007 07:10 PM
isaacson06
Apr 14, 2007 06:07 PM
AZNracerx1989
Sep 23, 2005 11:28 AM
Red D Dragon
Mar 29, 2004 05:41 PM
