Do i need a crank sensor?
Old May 11, 2004 | 06:57 PM
JAY's Avatar
JAY
Default Do i need a crank sensor?
Hey guys.
I have a 99 si with a P28 Hondata S200w boost. Im swapping in my built Ls/vtec this week. the new motor dosnt have a crank sensor by the oil pump. Do i need this? i dont think i do beings that im no longer Obd2 but i just wanted to check.
thanks
Old May 11, 2004 | 07:04 PM
m R g S r's Avatar
Default Re: Do i need a crank sensor? (JAY)
They don't really do much, and the b16 block that I'm putting in my car doesn't have one so I'm not gonna use it.
Old May 12, 2004 | 04:10 AM
EE_Chris's Avatar
Crank fluctuation sensor is OBD2....P28 is OBD1....no worries.
Old May 12, 2004 | 06:40 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Do i need a crank sensor? (EE_Chris)
Have had a crank angle CEL every since my car has been running. No problems
Old May 12, 2004 | 06:58 AM
PM-Performance's Avatar
Default Re: Do i need a crank sensor? (HybridHatch88)
if you sweitched to OBD1 which you had to , it wont look for that sensor anyway
Old May 12, 2004 | 06:59 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Do i need a crank sensor? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">if you sweitched to OBD1 which you had to , it wont look for that sensor anyway </TD></TR></TABLE>
I switched to OBD1 and now it throws code 9. When it was OBD0 it wouldnt rev over 3K
Old May 12, 2004 | 07:11 AM
So whats the code 9?
Old May 12, 2004 | 07:24 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">So whats the code 9?</TD></TR></TABLE>
Cylinder position sensor
Old May 12, 2004 | 07:25 AM
ok then put it back on if you want , but i went from obd2-to 1 and i have the p28 and it doesnt look for the sensor. you might have a wacked out conversion harness or something
Old May 12, 2004 | 07:33 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">ok then put it back on if you want , but i went from obd2-to 1 and i have the p28 and it doesnt look for the sensor. you might have a wacked out conversion harness or something </TD></TR></TABLE>
Thats what im thinking, it threw the code with the 93 GSR ecu im using, and a virgin P28 I tried
Old May 12, 2004 | 07:47 AM
EE_Chris's Avatar
CYP sensor is up inside the distributor and is needed. CKF sensor, specific to OBD2, is located on the oil pump.
You do NOT need the CKF sensor but you most certainly need the CYP input.
akinas-crx
Oct 28, 2011 06:00 PM
jjmcmana
Nov 1, 2008 09:02 AM
Spence
10
Apr 24, 2006 09:37 PM
FOMULA91
Nov 17, 2005 10:33 PM
