Do I need a block girdle? DID SEARCH
Old Apr 17, 2002 | 05:27 PM
2K_TEG's Avatar
Default Do I need a block girdle? DID SEARCH
Well, I did a search but it was inconclusive. I have a B18B getting GE sleeves, JE or Endyn pistons, eagle rods, TURBO. Looking for 350+ HP. Do I need a block girdle? I am not planning on high revs, just high boost. Someone set this straight once in for all. It is $400 I could use on something else if I do not need it. Thanks,
Old Apr 17, 2002 | 06:24 PM
sgT's Avatar
sgT
Default Re: Do I need a block girdle? DID SEARCH (2K_TEG)
high revs yes
if not then no.
just make sure you balance everything.
Old Apr 17, 2002 | 08:12 PM
2K_TEG's Avatar
Default Re: Do I need a block girdle? DID SEARCH (sgT)
high revs yes
if not then no.
What are you considering high revs. I was going to raise it to 7.3-7.5. Does it have any benefit whatsoever with high boost? Thanks again.
Old Apr 17, 2002 | 09:58 PM
2K_TEG's Avatar
up please
Old Apr 19, 2002 | 09:29 AM
X2BOARD's Avatar
bumpers...
Old Apr 19, 2002 | 09:41 AM
b18bturbo's Avatar
Default Re: Do I need a block girdle? DID SEARCH (X2BOARD)
it good to tie in block girlde to keep everyhting in tact at higher revs. Its not really necessary if you keep a stock like configuration. But for 270 for a block girdle i would getone.
Old Apr 19, 2002 | 09:58 AM
Speed PHreak's Avatar
Info for you to consider
https://honda-tech.com/zerothread?id=153009
and
https://honda-tech.com/zerothread?id=153011
Both are girdle related
thugsbryan
Mar 27, 2015 09:48 AM
f22abuilder
Feb 23, 2006 11:32 AM
LoSt is BlaCk
Aug 12, 2003 10:39 AM
BlwnBlue
Jan 19, 2002 08:44 AM
B18CHatch
Oct 18, 2001 03:06 PM
