Do I have Enought room?
here's a pic of my current header, I still finding parts for my turbo setup, but I'm afraid i won't have enough room between the radiator and my block for my turbo , pipingand manifold. Removing the a/c is no problem, I plan to do that anyways. The turbo I plan to use is a T3 if that helps. I will be running FMIC as well. Is there going to be room? What type of manifold should i use?
cuz it just seemed like there isn't enough room by looking at it. also i was in a minor frontal accident but it's suppose to be fixed. i doubt the rad moved a lot.
so what you're aying is if i don't get a kit, and do a custom turbo setup, it won't fit? i don't see why not, cuz the kits with the t4 compressor are bigger than the T3 i plan to use aren't they?
You should get the thin fans and mount them on the other side, having the fan push air instead of pulling it. Pepboys and Kragen have them I heard. This is what I am planning do. Check this thread out.
https://honda-tech.com/zerothread?id=342105
Dancing is Forbidden
Oct 27, 2005 06:33 AM
