Do I??????????????
Old Apr 8, 2003 | 06:12 PM
qqqq
Guest
Posts: n/a
Default Do I??????????????
Do I need the gasket between the mani and turbo or is it not nessecery?
Old Apr 8, 2003 | 06:20 PM
genop's Avatar
Default Re: Do I?????????????? (babyboib16)
I dont use one on mine. As long as the surfaces are perfectly flat (like they should be) you wont have any problems.
Old Apr 8, 2003 | 06:23 PM
qqqq
Guest
Posts: n/a
Default Re: Do I?????????????? (genop)
It looks flat but wont i have a exhaust leak if i dont put a gasket?
Old Apr 8, 2003 | 06:25 PM
genop's Avatar
get a straight edge and put it across the surface to see if it is perfectly flat.....if both surfaces are completly flat, where would it leak from?
Old Apr 8, 2003 | 06:26 PM
Ben Huynh's Avatar
Carbon works well at sealing leaks.
Old Apr 8, 2003 | 06:37 PM
ion_four's Avatar
Default Re: Do I?????????????? (ben@importparts.com)
This is true. I knew a guy that always put a thin layer of grease between his turbo and mani when it was apart to speed up this sealing.
Also, babyboi...why don't you put meaningful titles on your posts, you don't have to trick people into reading them
Old Apr 8, 2003 | 06:42 PM
qqqq
Guest
Posts: n/a
Default Re: Do I?????????????? (ion_four)
my bad i am not trying to trick anyone. thanks for the help.
i getz da chewin
Sep 14, 2009 10:15 PM
blakacintegra
Jun 20, 2007 05:21 PM
Nikoli
Jan 22, 2005 03:32 PM
JusT a Cx
May 12, 2004 08:58 AM
Ty.
Feb 26, 2004 11:56 PM
