Dizzy timing?
Old May 12, 2004 | 09:06 PM
SOHC_MShue's Avatar
Default Dizzy timing?
Hey guy's i have my ignition timing set right at 12 degrees on my y8 right now because thats what it is stock on the y8. I am wondering if i should run 16 though because i am using a p28 ecu which comes stock on a z6 motor with a stock ignition timing of 16 degrees. I am also running beerbongskickass's uberdata maps in my car. Since those maps were tuned for 16 degrees and i'm using a p28 which is made for 16 degrees at idle shouldn't I set mine to 16 or leave it at 12 because its a y8?
Old May 13, 2004 | 05:04 AM
SOHC_MShue's Avatar
Default Re: Dizzy timing? (SOHC_MShue)
bump
Old May 13, 2004 | 09:46 AM
SOHC_MShue's Avatar
Old May 13, 2004 | 10:31 AM
TurboBumblBee's Avatar
what do you think is a good idea? i would try 16 degrees and see if it runs better, i mean it i tuned for 16 degrees.. if it runs like crap, go back to 12
Old May 13, 2004 | 10:34 AM
SOHC_MShue's Avatar
Default Re: Dizzy timing? (Boostfedb18c1)
well i don't want to run 16 degrees and be detonating the **** out of my motor when it should be 12.
rass1313
Jan 21, 2007 06:44 PM
91integraLSVTEC
May 31, 2005 11:28 AM
Catman316
Jan 26, 2005 08:13 AM
SOHC_MShue
Jun 21, 2004 08:08 AM
