DIY: what are you using for pipe couplers?
Old Mar 10, 2004 | 11:38 AM
G2turbo_terror's Avatar
Default DIY: what are you using for pipe couplers?
Besides expensive silicon adapters what are people using for pipe couplers? I'm looking for something that can stretch between different diamiters (ie; 2.5 -3 1/8). People mention using radiator hosing but the auto part stores claim that 2.5 ID hosing doesn't exist.
I have found that belt hosing works very well and is not to expensive but it won't stretch at all. I bought 3' for $50 from Napa auto parts. Thanks guys.
Old Mar 10, 2004 | 11:42 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: DIY: what are you using for pipe couplers? (G2turbo_terror)
some people use plumbing connectors from home depot but they'll bulge out really bad at 10psi and pop quite often at 15psi.
i went to the local diesel shop and bought nomex hose by the foot for cheap.
Old Mar 10, 2004 | 11:44 AM
Default Re: DIY: what are you using for pipe couplers? (stackz)
Will nomex stretch between different pipe sizes?
Old Mar 10, 2004 | 11:48 AM
stackz's Avatar
Community Builder
not really and you dont really want anything that will stretch between pipe sizes either. anything that's elastic enough to stretch a 1/4" or more easy enough to go on the larger pipe will probably balloon up on you under boost and not last that long.
Old Mar 10, 2004 | 11:52 AM
b18bturbo's Avatar
I use the couplers from ATPturbo.com they are well prices and works great. Let me know if you need some i have alot of extra
Old Mar 10, 2004 | 02:01 PM
DaX's Avatar
DaX
Loved
Community Favorite
I bought my silicone couplers from roadraceengineering.com...I actually bought it by the foot...$25/foot is not too bad, compared to pre-cut pieces.
Old Mar 10, 2004 | 03:18 PM
USDM 4G VTEC's Avatar
Home depot has the great selection and best prices
they even include the clamps
Old Mar 10, 2004 | 03:24 PM
M.A.R.C.'s Avatar
Default Re: (USDM 4G VTEC)
i used 2.5" heavy duty radiator hose from NAPA.. was like $15 for a 1ft stick i think
Old Mar 10, 2004 | 03:41 PM
buda18's Avatar
Default Re: (CivicRyda2k)
well i guess since we're on the subject AGAIN
just to be on the safe side, would it be okay to spread a lil rubber cement on the piping before putting the hose on there? whether it be silicone or radiator hose?
i just dont want something thatll eat the hose or just cause it to act weird...yeah itll probably be a pain to get it off later. any info.. thanks
Old Mar 10, 2004 | 03:45 PM
Default Re: (buda18)
why u wanna use cement??
to avoid boost leaks?
just put them in tight
Old Mar 10, 2004 | 03:48 PM
7808's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">i used 2.5" heavy duty radiator hose from NAPA.. was like $15 for a 1ft stick i think</TD></TR></TABLE>
so coolant hose will work for boost?
quikB18B's Avatar
You guys go through so much trouble, when it's so simple. You'd think of all the forunms on honda-tech Fi would have the least tight wads
Like Viren said atpturbo.com has very nice prices on precut connectors
Im running thier connectors along with T bolt clamps and I have never had a pipe blow off.
Thier connectors are only $6 a piece.
Old Mar 10, 2004 | 03:49 PM
M.A.R.C.'s Avatar
Default Re: (fuctup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">
so coolant hose will work for boost?</TD></TR></TABLE>
the HEAVY DUTY ones... like the ones they use on big *** trucks... what the hell else would use a 2.5" radiator hose lol
z395civic
Nov 16, 2008 06:35 PM
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
birz
Apr 19, 2004 04:40 PM
