charge pipe popped up
Old Apr 18, 2004 | 07:31 PM
birz's Avatar
Default charge pipe popped up
Hi, my charge pipe popped up again on the throttle body, would it be benifit if I buy a turbo clamp, cause the one I currently have is a 0.99c bought at home-depot. No matter how hard I tighten the clamp it always pop time to time.
Old Apr 18, 2004 | 07:34 PM
J337_UNIT's Avatar
Default Re: charge pipe popped up (birz)
silicone couplings are probably your best bet
Old Apr 18, 2004 | 07:35 PM
boosted_dc2's Avatar
Default Re: charge pipe popped up (J337_UNIT)
use a t-bolt type clamp.
Landon
Old Apr 18, 2004 | 09:07 PM
integrx's Avatar
New User
hair spray, i read not too long ago
Old Apr 18, 2004 | 10:21 PM
AspectIndustries's Avatar
Default Re: charge pipe popped up (integrx)
Anyone know where sells the T-bolt clamp locally? Auto Stores? Thanks...
I've hear hair spray works well also, just to hold the slipping from boost pressure.. But most def upgrade to a nicer clamp....
Old Apr 18, 2004 | 10:39 PM
bradford's Avatar
Default Re: charge pipe popped up (synik)
I prefer to use regular hose clamps as opposed to t clamps, Ive had less slipping with regular stainless hose clamps. Also do you have a bead on the pipe? If not a bead around the pipe would keep it from popping off.
Old Apr 18, 2004 | 11:35 PM
PrecisionH23a's Avatar
These clamps are the best. Please ignore the rubber 90 boot
Old Apr 19, 2004 | 04:31 AM
91civicDXdude's Avatar
i've boosted up to 12psi on home depot rubber connectors and normal radiator hose clamps. I triple clamp each connector though, so they dont bubble in the middle and so it will hold better. on the compressor outlet of my 14B, i have 5 clamps on one connector becuase no matter what i did, it always popped off
USE MORE CLAMPS!
Old Apr 19, 2004 | 05:14 AM
m R g S r's Avatar
Default Re: (91civicDXdude)
Using 5 clamps is stupid. You could probally spend less on one good clamp and it will hold.
Old Apr 19, 2004 | 06:31 AM
quikB18B's Avatar
Default Re: (m R g S r)
I've heard people on the board mention that Nappa carries some type of T bolt clamp, Ive never seen it myself so Im not sure on the type it is.
There is a place online that sells the T bolts for cheap though, its partssystems or something like that. Do a little searching and im sure you can find the link. There around $2.50
Old Apr 19, 2004 | 06:32 AM
B18Flip's Avatar
Default Re: (quikB18B)
Mcmaster and atpturbo has them
Old Apr 19, 2004 | 06:36 AM
DaX's Avatar
DaX
Loved
Community Favorite
Parts Systems has the cheapest clamps. They are excellent quality.
Old Apr 19, 2004 | 07:35 AM
TeamCracka's Avatar
Default Re: (DaX)
Most local auto parts stores should carry them, Home Depot where I live even does. Just make some calls
Old Apr 19, 2004 | 03:18 PM
integrx's Avatar
New User
Default Re: (TeamCracka)
napa for sure has them, its called heavy duty clamp
Old Apr 19, 2004 | 03:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Using 5 clamps is stupid. You could probally spend less on one good clamp and it will hold.
okay, i'll put one clamp on my connector and see how long it holds.
dumbass.
Old Apr 19, 2004 | 04:32 PM
quikB18B's Avatar
Default Re: (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">he was just giving you a suggestion. and why call him a dumbass for saying what youre doing is stupid? although it is stupid. obviously youre not doing something right to have to use 5 clamps to hold on one connector. so i think you're the dumbass. </TD></TR></TABLE>
Exactly my thoughts, Hes right. All he said is what you are doing is stupid, and you call him a dumbass
Your 5 clamps .99 cents a piece cost more than my one T bolt clamp, that does the job better than a Worm clamp can do
You should take his suggestion and get a Good clamp rather than call him a dumbass.
Old Apr 19, 2004 | 04:40 PM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">i've boosted up to 12psi on home depot rubber connectors and normal radiator hose clamps. I triple clamp each connector though, </TD></TR></TABLE>
Maybe this is the reason you have to use so many clamps
MiNcEdMeAt
Welding / Fabrication
Oct 26, 2011 02:02 AM
hondaapi
Jul 4, 2006 08:21 PM
Btothe3rdDegree
Feb 13, 2005 02:12 AM
G2turbo_terror
Mar 10, 2004 03:49 PM
Aeka GSR
Jun 12, 2002 07:22 PM
