DIY water injection
Old Feb 21, 2004 | 02:31 AM
mattcalica's Avatar
Default DIY water injection
okay, so i have been researching a little about water/alcohol injection...then it came to me...the windshield water pump...do you believe that if i hook up the proper sized nozzle to the pump, it would be an efficient water injector? i plan on hook up the winshield pump to a hobbs pressure switch, and have a hose run up to a fitting near the throttle body, with a nozzle...i really think this will work. do you guys see any problems with this setup?
Old Feb 21, 2004 | 03:45 AM
mrx's Avatar
mrx
Default Re: DIY water injection (mattcalica)
I don't think so, because the pump makes not enoght pressure... i would install a inline fuel pump instead and use a normal fuel injector... this could make the proper vaporisation.
Old Feb 21, 2004 | 04:14 AM
hpfsi's Avatar
It probably wouldn't work too well against pressure in the intake, but... look at the nozzles at mcmaster.com on catalog pages 1898-1901. I was thinking of misting my fmic. In the worst case you already have the nozzle, you can just get a real pump.
*edit* - if you do try it, please check for proper atomization off of the vehicle. You don't want water pooling in your cylinders really.
Old Feb 21, 2004 | 08:43 AM
totalimpact's Avatar
Ya, what they said, you need a high pressure pump. Fuel injector is a bad idea because even though it makes a fine spray, many people say its still not fine enough, you cant have any drops forming in your intake. You can buy aquamist injectors on ebay for like $15-$20. That would be your best bet.
Read the H20 forums also - http://www.h20injection.com
BB6-213
Jul 23, 2011 01:23 PM
ranta18
Nov 12, 2009 08:04 AM
mattcivic
Jun 21, 2005 10:07 PM
tominos
Sep 10, 2004 08:38 PM
Sinner
Feb 25, 2004 09:21 PM
