... diy throttle body porting... comments/thoughts
Old May 6, 2003 | 05:35 PM
1.8T_EG's Avatar
Default ... diy throttle body porting... comments/thoughts
... i searched the archives and found mixed reactions... some good, some bad... so i am wondering what everyone thinks now... if you have the time, post and lemme (and everyone else) know what you think... thanks...
((just some stuff from the archives))
i found that if you are going to straight bore it out, you need a new throttle plate (sized appropriately)... if you dont wanna get the new plate, then you can taper it (similar to the spoon tb)... anything else i missed or should know?... thanks...
Old May 6, 2003 | 07:47 PM
ion_four's Avatar
Default Re: ... diy throttle body porting... comments/thoughts (1.8T_EG)
I tapered my throttlebody when I had to take it off, anyway, and I would say it did not make a noticebale difference, though this was before I went turbo, so maybe it would be more pronounced now. If you've got it off, why not? at the least you could smooth out the transitions from cast to machined on either side of the plate.
Old May 7, 2003 | 05:30 PM
1.8T_EG's Avatar
Default Re: ... diy throttle body porting... comments/thoughts (ion_four)
... thanks for the info... anyone else?... i was hoping to use my stock gsr throttle body with a skunk2 manifold... planning emulating the spoon tb if possible... lemme know what you think... thanks in advance...
Old May 7, 2003 | 05:35 PM
93LSivic's Avatar
IMO its not worth it unless your gonna use a larger butterfly too. But big tb's wont come into play until your making a lot of hp.....stock should be fine.
Old May 7, 2003 | 09:58 PM
1.8T_EG's Avatar
Default Re: ... diy throttle body porting... comments/thoughts (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">But big tb's wont come into play until your making a lot of hp.....stock should be fine.</TD></TR></TABLE>
... just curious, what's your definition of 'a lot of hp'?...
BLK99VTECR
Feb 15, 2004 02:37 AM
NeVeR bLoWn
Jan 13, 2003 11:38 PM
EGsex
Dec 10, 2002 03:49 PM
GSxRated
May 9, 2002 04:57 PM
Sloth
Mar 22, 2002 01:06 PM
