Displacement equation?
(1/2(Bore in CM) squared) * 3.1459 * Stroke * cylinders.
For example on a d16, 75 MM bore with 90MM stroke:
1/2(7.5CM ) squared * 3.1459 * 9 CM * 4 = 1592 CC
Check 'volume of a cylinder' in the geometry book
Volume of a cylinder =
pi * r² * stroke ... or
pi * (bore/2)² * stroke
then multiply by the number of cylinders to get total engine displacement.
Okay, I know I can get it that way, but awhile back I saw a really easy equation that just involved 3 numbers multiplyed by each other. I remeber playing with it a bit, but I can remeber what the third number was. I know for sure it was bore x stroke x another number like .8933423 (some long decimal). Or was I just dreaming?
BORE X BORE X STROKE X .0031416 = DISPLACEMENT in CC
Thank you, thats what I was looking for!!!!!!!!! I was really starting to wonder if I dreamed the equation!!!!
Ummmm, Okay, but you do realize this is the same equation everyone else gave you 3-4 times!
I put it in the simplest form since it's the easiest to comprehend!
I have more equations/calculator links somewhere!
https://honda-tech.com/zerothread?id=125034
Yeah, I gave you the wrong equation. I think my equation would give you the area of the walls of the cylinders, though!
Yeah....that's kind of useless
Damn! Five years of college down the drain!
pi * r² * stroke * cylinders is the right one.
[Modified by Lsos, 4:53 PM 3/18/2002]
Leo.
Dec 8, 2006 02:56 PM
Gant
May 28, 2005 08:10 PM
