disadvantages of a short dump tube?
Re: disadvantages of a short dump tube? (blinx9900)
There's no rule that would apply to everyone, it would probably require some calculations that aren't really worth it, IMO. Shorter is always better assuming that you have gotten the exhaust to leave the engine bay. You don't want to exhaust in there, as was stated above, that's where your motor is breathing from, so you want clean air in there.
Matt
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">is there an ideal length to keep noise down?</TD></TR></TABLE>
No but ideal placement would be under the oil pan to where the exhaust gases are being detered from your engine bay.
Re: (envee)
If there's a bit more restriction from the length, it will just open the WG valve a tad more automaticly. Unless you have serious problems, such as a 2" dump tube merging with a 2.25" DP and running very low psi resulting in mad boost creep, you should just focus on getting it away from the engine bay. As most people with good WG setups that dump back into the DP rarely have issues, I can't see a dump tube creating issues.
Re: disadvantages of a short dump tube? (nexxxt)
i had open dump....it gets kinda annoying....so just try and re route it back into the downpipe......
but then again i ran open downpipe also, and that was annoying, but it made a shiton more power and spooled so much faster i just dealt with it haha
Re: disadvantages of a short dump tube? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">i had open dump....it gets kinda annoying....so just try and re route it back into the downpipe......
hmmm, everybody says its loud by i have a friend with an lsvtec turbo eg and his dumptube is about 2ft long and its really quiet ive heard it at 7psi, ive heard it at 25psi its just no any louder than an na motor.
i guess the problem is what do you consider loud, to each his own on this one i guess...
i guess the problem is what do you consider loud, to each his own on this one i guess...</TD></TR></TABLE>
Pretty much, every car I have driven or heard, usually the muffler is more of the problem with the noise.
Re: disadvantages of a short dump tube? (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">Pretty much, every car I have driven or heard, usually the muffler is more of the problem with the noise. </TD></TR></TABLE>
you never been in a rotary tube with an open dump all you hear is the WG and its loud as fawk!!!!
KevinEF7
01-02-2013 06:53 PM
Terminator Sol
10
11-10-2004 06:00 PM
