Disadvantage from TOO BIG intercooler?
Old Dec 23, 2005 | 07:19 AM
mrx's Avatar
mrx
Default Disadvantage from TOO BIG intercooler?
Hallo,
i replan my setup currently to realize some lower top hp numbers and gain some spool up time for better daily drivability.
now i have my old intercooler and want to know if there are and major disadvantages for a setup which will be producing around 300-350whp. My major concern is about the spool up and throttle response.
my intercooler is 27" x 10" x 3" ...
hope to get some serious informations.
Best regards
Old Dec 23, 2005 | 07:22 AM
The Weather Man's Avatar
I'm assuming it depends on the pounds you're pushing through the charge pipes.
What psi are you running?
Old Dec 23, 2005 | 09:46 AM
mrx's Avatar
mrx
Default Re: (TheKINGPin)
i think will be take the tubo to it's efficiency limit... i guess something like 20-21psi on the track... mabe something arount 14-16psi daily driven
GT28RS .64ar turbine housing (because of spool up time) on a B16 engine.
Old Dec 23, 2005 | 01:21 PM
z6's Avatar
z6
no disadvantage unless its a shitty i/c and costs you alot of pressure loss
Old Dec 23, 2005 | 04:15 PM
JDogg's Avatar
Default Re: (z6)
that 0.63 ar is gona SUCK... that thing isnt gona make power past 7500 rpms.. the 86a/r spools so fast its almost violent.
a big i/c takes longer for the turbo to fill up w/boost.. it will add a touch of lag
Old Dec 23, 2005 | 04:25 PM
HondaEK9's Avatar
Default Re: Disadvantage from TOO BIG intercooler? (mrx)
the bigger the intercooler the longer it takes to spool the turbo
Old Dec 23, 2005 | 06:19 PM
Full-Race Javier's Avatar
an oversized fmic can also reduce the airflow to the other important heat exchangers....rad, condenser, oil/ps/trans cooler etc. most 3.0 in thick cores with normal fin density work well on a street car though
Old Dec 24, 2005 | 02:28 AM
mrx's Avatar
mrx
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">that 0.63 ar is gona SUCK... that thing isnt gona make power past 7500 rpms.. the 86a/r spools so fast its almost violent.
a big i/c takes longer for the turbo to fill up w/boost.. it will add a touch of lag</TD></TR></TABLE>
Hi,
yes i know that the .63ar will kill some top end, but, i rev the car only to 8000rpm and when i loose some topend for the last 500rpm it doesn't care. its far more important that the turbo spools very early (and with very early i don't think about 4000rpm)
i have a friend with a GT28RS .82ar on a B16 and the lag is too big in my eyes for my application.
i have tuned another car with a GT28R on a B16 and the spool up was amazing, just like i want it, but i have to take a T3 Exhaust housing because of my manifold and i want a bit more hp then the GT28R can deliver.
I asked Jeff Evans and he said, that i can make ~325whp on a 28RS .63ar which is enough for me... even if i loose some top end tourqe. But if anyone has a dyno sheet or first hand informations about the 28RS .63ar i'am glad to hear about them.
Thanks
Malte.
b20beast83
Feb 26, 2010 10:02 AM
integracivic94
Sep 4, 2006 10:08 AM
Red D Dragon
Nov 27, 2005 11:39 AM
mrx
Jun 5, 2005 01:34 PM
dnbruut
Feb 28, 2005 02:06 PM
