Disabling Knock sensor on B18C/b16 setup
Old Mar 4, 2003 | 09:20 AM
RAWB's Avatar
Default Disabling Knock sensor on B18C/b16 setup
I'm planning on installing a ZDYNE unit on my B18C block/B16a head(nonOBD) setup. Currently, I'm using the PR3 ECU. My question, in order to run the ZDYNE I have to use a PR4 ECU(which does NOT have knock sensor) the VTEC will also be wired; BUT is there any consequences I'm opening myself up to by doing this? I've heard the ECU ignores the KS past 5K RPM, anyway. TIA
Old Mar 4, 2003 | 09:27 AM
Flamenco-T's Avatar
Default Re: Disabling Knock sensor on B18C/b16 setup (RAWB)
yes, stock ECU ignore knock sensor past 5K RPM...
hondacrx90
Apr 9, 2004 08:53 PM
FitCRX
May 12, 2003 09:30 AM
hurleyburley
Jul 25, 2002 11:55 AM
