difference between stages of wheels?
Old Nov 17, 2005 | 01:26 PM
SpoolnByYou's Avatar
Default difference between stages of wheels?
sup guys,
i was just wondering what is the difference between the 3 stages of the exhaust wheel. like what makes a difference if its a stage 1 stage 2 or stage 3 exhaust wheel?
Old Nov 17, 2005 | 01:29 PM
Turbogixxer's Avatar
Default Re: difference between stages of wheels? (SpoolnByYou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff evans for a long time ago &raquo;</TD></TR><TR><TD CLASS="quote">There is stage 1, 2, 3 and 5. All of the trims vary in terms of how aggressive the angles the blades are placed, and overall size of the exhaust blade. The stage 1 blade will give you the quickest spool up, but wont support give the maximum amount of power. Stage 5 is at the opposite end of the spectrum being the largest, and most aggressive. Stage 1, 2 and 3 are garret parts and the stage 5 is a turbonetics developed wheel. The angles and size of the exhaust wheel dictate how the air being forced into the housing is used by the wheel. The shallowier the angle of the blades the easier the wheel will turn. The sharper the angle, the harder the wheel (laggier stage 3 and 5) will spin, but carries more energy. More energy means more overall gases energy turned into mechanical energy.</TD></TR></TABLE>
I am too lazy to type that
Old Nov 18, 2005 | 05:56 PM
rhd's Avatar
rhd
there's a stage 4 wheel now, as well
Old Nov 18, 2005 | 06:12 PM
1fastgsrturbo's Avatar
Default Re: (rhd)
dont forget about the stage 5 wheel
Old Nov 18, 2005 | 06:37 PM
Axle's Avatar
Default Re: (1fastgsrturbo)
What about amount of blades? I've seen some mention of 7 blades instead of 6. Does the quantity of blades also vary with stages or just manufacturers?
Old Nov 18, 2005 | 06:39 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Axle)
the stage describes the angle of the blades and the overall diameter of the wheel... higher the number the more they flow, the bigger they are and the more laggy they are.... number of blades is dependent upon what purpose the turbine was originally built for.... more blademore back pressure = quicker spool but so so top end
D16SohcVtec
Feb 29, 2008 06:11 AM
DelSolMike
Sep 3, 2005 08:48 AM
pip9
Nov 20, 2004 05:52 PM
djmatix
Jul 23, 2003 12:36 PM
Boost2NA
May 4, 2003 08:09 AM
