difference between blue and black top dsm injectors?
Old Jun 27, 2003 | 03:41 AM
drjondurst's Avatar
Default difference between blue and black top dsm injectors?
I seached and came up with nothing.
Is there any difference between the blue and black top dsm injectors? What do the different colors signify, different years?
Old Jun 27, 2003 | 04:46 AM
JDMCRX's Avatar
Default Re: difference between blue and black top dsm injectors? (drjondurst)
Well i know the BLUE=450cc
YELLOW=510cc EVO injectors
BLACK= beats the **** out of me never knew they came
with black tops
PINK= 235cc non turbo injectors
These are what i know correct me if im wrong
Old Jun 27, 2003 | 04:53 AM
92sleepR's Avatar
New User
Black top are newer but as far as any physical diferences I haven't a clue.
Mike
Old Jun 27, 2003 | 05:15 AM
Spudddy's Avatar
i have a set of black top 450's in my si.. no problems work great
Old Jun 27, 2003 | 05:29 AM
mamaboy's Avatar
Black top 450cc's are from 2G DSM's
Old Jun 27, 2003 | 07:15 AM
drjondurst's Avatar
Default Re: difference between blue and black top dsm injectors? (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">Black top 450cc's are from 2G DSM's</TD></TR></TABLE>
and blue tops are from 1g's correct? this is the only difference? you can still use the same napa seals kit?
Old Jun 27, 2003 | 07:19 AM
JDMCRX's Avatar
Blue top 1G
Old Jun 30, 2003 | 09:46 AM
Spudddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">
and blue tops are from 1g's correct? this is the only difference? you can still use the same napa seals kit?</TD></TR></TABLE>
yes the seal kit works fine
Old Jul 3, 2003 | 01:31 AM
JDM H22A's Avatar
Blue tops are 1g DSM injectors, and black tops are 2g DSM injectors . got that straight from homemadeturbo.com
Old Jul 3, 2003 | 03:23 AM
toxicshit's Avatar
Does annyone of you know if i can get nappa seals in europe?
Old Oct 25, 2003 | 11:18 AM
gelok's Avatar
Default Re: (toxicshit)
does the black top and blue top dsm injectors has the same clips???
Old Jan 17, 2004 | 10:38 PM
dubniK's Avatar
Default Re: (redintegra_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redintegra_18 &raquo;</TD></TR><TR><TD CLASS="quote">does the black top and blue top dsm injectors has the same clips??? </TD></TR></TABLE>
Old Jan 19, 2004 | 09:56 PM
boredracer408's Avatar
Default Re: (slow ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow ek &raquo;</TD></TR><TR><TD CLASS="quote">does the black top and blue top dsm injectors has the same clips??? </TD></TR></TABLE>
yes they do.
Old Jan 19, 2004 | 10:12 PM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">Does annyone of you know if i can get nappa seals in europe?</TD></TR></TABLE>
I am not sure but I dont think so.
you may try to find a similar product in one of your auto parts stores there... just a generic fuel injector seal kit.
Old Jan 28, 2019 | 03:09 PM
Drew Loving's Avatar
Ihave a 97 delsol needing injectors. Are u using a resistor box for them ? Do u need a resistor Box for for black tops ??
Old Jan 28, 2019 | 03:29 PM
Chrisfrom1986's Avatar
Wow, 15 year old thread bump.
Old Jan 28, 2019 | 09:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
2003 called... they want their junk azz Mitstupidity fuel injectors back.
Come on man, fuel injector technology has improved by leaps and bounds in the last ten years. Anybody who is selling DSM injectors is doing it so they NEVER have to look at or use another set again.
Old Jan 29, 2019 | 09:47 AM
TheShodan's Avatar
Moderator
Yes. You need them for ALL regardless of blue or Black top.
Thanks for the memories from back than.
JDMeg95
Nov 13, 2007 03:14 PM
b18bye
Mar 16, 2006 04:11 AM
nekoabandoned
Dec 31, 2005 06:36 PM
ArchAngel Sabastian
Jan 11, 2004 07:02 PM
Leb_CRX
May 13, 2003 05:52 PM
