difference between blue and black top dsm injectors?
I seached and came up with nothing.
Is there any difference between the blue and black top dsm injectors? What do the different colors signify, different years? |
Re: difference between blue and black top dsm injectors? (drjondurst)
Well i know the BLUE=450cc
YELLOW=510cc EVO injectors BLACK= beats the fuck out of me never knew they came with black tops PINK= 235cc non turbo injectors These are what i know correct me if im wrong |
Black top are newer but as far as any physical diferences I haven't a clue.
Mike |
i have a set of black top 450's in my si.. no problems work great
Black top 450cc's are from 2G DSM's
Re: difference between blue and black top dsm injectors? (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy »</TD></TR><TR><TD CLASS="quote">Black top 450cc's are from 2G DSM's</TD></TR></TABLE>
and blue tops are from 1g's correct? this is the only difference? you can still use the same napa seals kit? |
Blue top 1G
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst »</TD></TR><TR><TD CLASS="quote">
and blue tops are from 1g's correct? this is the only difference? you can still use the same napa seals kit?</TD></TR></TABLE> yes the seal kit works fine |
Blue tops are 1g DSM injectors, and black tops are 2g DSM injectors . got that straight from homemadeturbo.com
Does annyone of you know if i can get nappa seals in europe?
Re: (toxicshit)
does the black top and blue top dsm injectors has the same clips???
Re: (redintegra_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redintegra_18 »</TD></TR><TR><TD CLASS="quote">does the black top and blue top dsm injectors has the same clips??? </TD></TR></TABLE>
Re: (slow ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow ek »</TD></TR><TR><TD CLASS="quote">does the black top and blue top dsm injectors has the same clips??? </TD></TR></TABLE>
yes they do. |
Re: (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit »</TD></TR><TR><TD CLASS="quote">Does annyone of you know if i can get nappa seals in europe?</TD></TR></TABLE>
http://images.honda-tech.com/set1//smile/emcrook.gif I am not sure but I dont think so. you may try to find a similar product in one of your auto parts stores there... just a generic fuel injector seal kit. |
Originally Posted by Spudddy
(Post 5777484)
Wow, 15 year old thread bump.
Originally Posted by Drew Loving
(Post 51845508)
Ihave a 97 delsol needing injectors. Are u using a resistor box for them ? Do u need a resistor Box for for black tops ??
Come on man, fuel injector technology has improved by leaps and bounds in the last ten years. Anybody who is selling DSM injectors is doing it so they NEVER have to look at or use another set again. |
(Post 51845508)
Thanks for the memories from back than. ;) |
