Did i get the wrong turbo?
Old Mar 5, 2002 | 06:13 PM
2K1NBGSR's Avatar
Default Did i get the wrong turbo?
Ok, i have begun my Drag 3 turbo install, and i have been asking about these threaded holes on the side of my turbo, and many have replied that i have a water-cooled turbo, and that Drag 3's are supposed to be oil-cooled only turbos?
Here's a previous thread i started, and the picture shows exactly what my turbo looks like with the holes on the side. https://honda-tech.com/zerothread?id=140305
Thanx
[Modified by 2K1NBGSR, 3:14 AM 3/6/2002]
Old Mar 5, 2002 | 06:18 PM
DragII's Avatar
Default Re: Did i get the wrong turbo? (2K1NBGSR)
The holes next to the oil drain hole are for the oil drain flange bolts. You can disregard the holes by the feed line hole.
Ben@importparts already answered your question right here
did you somehow miss this reply?
Old Mar 5, 2002 | 06:19 PM
D-SPEED's Avatar
Default Re: Did i get the wrong turbo? (DragII)
Old Mar 5, 2002 | 06:26 PM
2K1NBGSR's Avatar
no, if you look at the previous thread, it seems that i have gotten a water-cooled turbo, look at the picture in the linked thread.
Old Mar 5, 2002 | 06:27 PM
DragII's Avatar
I did...the pic looks normal to me.
Old Mar 5, 2002 | 06:29 PM
2K1NBGSR's Avatar
Really? Well you see the oil feed line in the top, the oil drain line would be on the bottom, now there's a hole on the side of the casing, facing directly towards you, what hooks up to this hole?
Old Mar 5, 2002 | 06:44 PM
DragII's Avatar
ahh I see what you are saying....is the hole on the side threaded?
Old Mar 5, 2002 | 06:50 PM
2K1NBGSR's Avatar
Yep, there's a hole on both sides, opposite of each other.
Hole is just a little smaller than the oil drain line.
Old Mar 5, 2002 | 07:02 PM
boomslang's Avatar
You have a watercooled center section. Either run coolant lines to it or leave them open to the air.
Old Mar 5, 2002 | 07:12 PM
DragII's Avatar
Default Re: Did i get the wrong turbo? (Inlinefour)
Old Mar 5, 2002 | 07:35 PM
*Boostwerks*'s Avatar
I would run coolant lines. I know that some kits do not have water cooled turbo's but it is safer for the berrings and you do not need to let it idle as long after a hard run. The water keeps the center section cooler, so the oil does not carbonize and ruin the berrings.
Hell, why not run them????
[Modified by Bryson, 8:36 PM 3/5/2002]
Old Mar 6, 2002 | 02:19 AM
2K1NBGSR's Avatar
Default Re: Did i get the wrong turbo? (Bryson)
Ok, if i do decide to run them, what would they hook up to??
Also if i got the wrong center section, then what's to say i didn't get the wrong turbo period, like A/R and trim?
Old Mar 6, 2002 | 02:33 AM
98Psi ITR's Avatar
Mitsu turbo's on a honda...noooooooo jk.
Old Mar 6, 2002 | 10:19 AM
Default Re: Did i get the wrong turbo? (98Psi ITR)
I am using a Mitsu t25 on my ZC with no problems. WAY CHEEPER than a using one of these Drag thing a ma bobs. Yes it is tiny compared to a T3 but is CHEEP.
There is a line that runs from the EACV to the TB and the TB back into the block. You can run a line from the EACV to the TURBO and then have it run from the TURBO to the Block. Easy as pie, and way better than no water line.
jel002
Dec 30, 2004 12:15 PM
4_door_teg
Dec 7, 2004 10:30 AM
Turbo-Mind
Apr 3, 2003 11:53 AM
1sick4door
Feb 27, 2002 02:13 PM
