Did a compression test today, does this sound okay??
Old Sep 14, 2002 | 11:58 PM
TurBoXBirD16's Avatar
Default Did a compression test today, does this sound okay??
D16Z6 w/ 100 K miles
all four cylinders are around 150
it was tested with a hot - warm motor..
i did it around 15 mins after the car shut down
does this sound good??
it scared the sht out of me when i saw 150
coz i used to have around 175... then i realized that I am doing on a hot motor..
when i got 175, it was a cold motor, did it in the morning..
does 150 in a hot motor sound alright ??
Old Sep 15, 2002 | 01:04 AM
ninesecrx's Avatar
Default Re: Did a compression test today, does this sound okay?? (xbird)
Sounds fine...
Old Sep 15, 2002 | 05:57 AM
DRAGLS's Avatar
u really want to find out in what condition yout rings are in do a leak down test
Old Sep 15, 2002 | 07:40 AM
TimoneX's Avatar
New User
Default Re: Did a compression test today, does this sound okay?? (DRAGLS)
...or for a simple quick & dirty test, you can try the old wet compression test. Put a bit of oil in each cylinder before you crank the engine, and look for a compression spike & then drop. This would indicate a poor seal between the rings and cylinder walls, which was momentarily sealed by oil.
Uncle Ben's
Dec 8, 2007 12:21 PM
crxowner
Mar 5, 2006 11:21 AM
sohctodohc
Oct 24, 2004 07:40 PM
Sport_Injected
Aug 16, 2004 09:06 PM
gsr~hatch
Apr 17, 2003 03:19 PM
