Detonation problem on ls turbo
Old Aug 10, 2003 | 02:10 PM
ls-t del sol's Avatar
Default Detonation problem on ls turbo
Just recently, I have been noticing detonation at part throttle ONLY, at 3k- 4k rpm...sounds like a loose valvetrain bolt, but its prob detonation
i have checked the plugs, they look ok...black towards the base and the nose/tip is whitish/brown.
Setup--
b18b, t3/60-1, uberteg chip, dsm 450's
i get no detonation under full throttle, and the timing is stock with 1 deg of retard per psi
Im thinking/hoping it is a fuel filter, or possibly injectors...the uberteg runs extremely rich so i dont think its because of lean conditions
Any other ideas??
Old Aug 10, 2003 | 05:48 PM
LS_REX's Avatar
Default Re: Detonation problem on ls turbo (SolReaver)
Could be a bad O2 sensor. I had one go bad before I was boosted...It never threw a code but was still bad enough to give me a killer hesitation (way lean) at part throttle when warm.
Rob
teg racer 877
Oct 25, 2009 06:12 PM
StreetEG
Dec 11, 2007 11:07 AM
97grnrs
Mar 8, 2007 03:02 PM
turboteg2nv
Nov 28, 2005 10:29 PM
zseeanz
Nov 23, 2003 08:55 AM
