Dependable Turbo?
Old Aug 20, 2006 | 05:14 PM
EKBOOSTDREAMS's Avatar
Default Dependable Turbo?
I'm just wondering will a stock b16a with 6-8lbs of boost be dependable for a daily driver? Also if I build it up and run more boost will it stay dependable as long as I have it tuned? Also open to suggestions as of how to keep turbo dependable as a daily driver.
Old Aug 20, 2006 | 05:22 PM
teg racer 877's Avatar
Default Re: Dependable Turbo? (EKBOOSTDREAMS)
the dependability of a turbo car is related to 3 things:
1 how well it was built
2 the quality of parts used (no ssac!!)
3 the tune
Old Aug 20, 2006 | 06:59 PM
Default Re: Dependable Turbo? (teg racer 877)
What about a stock b16 setup with a brand new turbonetics turbo and all new parts...FMU...etc? 6-8lbs of boost and a good tune....dependable?
Old Aug 20, 2006 | 07:30 PM
StreetEG's Avatar
why do people still have fmu in their vocabulary
Old Aug 20, 2006 | 07:48 PM
Default Re: Dependable Turbo? (StreetEG)
I know I shouldnt use the fmu setup but its what I have right now. What system would you suggest? I'm really trying to find out how to make a dependable turbo car, so please any suggestions to make this possible are welcome
Old Aug 20, 2006 | 08:09 PM
hondaaccord94's Avatar
you can use hondata,crome pro,aem ems etc.. way more reliable then any fmu.my opinion
ask whoever is tuning your car what he feels compfortable with.
Old Aug 20, 2006 | 08:17 PM
95dc2teg's Avatar
Default Re: Dependable Turbo? (hondaaccord94)
FMU and dependable dont go well together. Just get some DSM injectors with a resistor box, get your ecu chipped and have someone tune it with crome, you will be set.
Old Aug 20, 2006 | 08:43 PM
Default Re: Dependable Turbo? (95dc2teg)
Yea, all opinions are sounding better than fmu...keep it coming.
Old Aug 20, 2006 | 08:56 PM
EK k kay's Avatar
Routine maintenance helps a lot as well. (More frequent oil changes, change plugs more often, keep eye on coolant and temperatures etc.)
Old Aug 20, 2006 | 09:12 PM
Default Re: Dependable Turbo? (EK k kay)
Is it true that most daily driven turbo cars overheat? Also what are some of the ways to keep the engine temps down?(Bigger radiator, hi-flow fans...etc) Thanks for the input keep it coming.
Old Aug 20, 2006 | 09:25 PM
IRONlung201's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKBOOSTDREAMS &raquo;</TD></TR><TR><TD CLASS="quote">Is it true that most daily driven turbo cars overheat? Also what are some of the ways to keep the engine temps down?(Bigger radiator, hi-flow fans...etc) Thanks for the input keep it coming. </TD></TR></TABLE>
Not true at all. A healthy engine with a propper tune, and a good radiator and fan setup, should never overheat. Be sure to propperly top off and bleed the cooling system after assembly, and you should be good to go. If a car is experiencing overheating issues, there is a problem somewhere in the setup, it wont be just because its turbo.
Old Aug 21, 2006 | 10:33 AM
Default Re: Dependable Turbo? (IRONlung201)
Ok...sounds good. I know some people who drive boosted civics around with no problem, but I know a lot of people who have lots of problems. But like you said it's all on the turbo and cooling setup, and the tune.Im just trying to see how to eliminate all problems that may come along after the install is complete.Keep the advice coming.
Old Aug 21, 2006 | 03:39 PM
emotionisdead's Avatar
Very Emergency!!
it's all in the tune. don't get too overly crazy with ignition timing and run richer on the a/f scale.
savestheday
Feb 26, 2011 07:24 AM
0618turbocivic
Jul 10, 2006 06:24 PM
XES
Oct 19, 2005 05:50 PM
1hotvtec
Sep 28, 2003 04:14 PM
E. Honda
Jun 18, 2002 02:56 PM
