DeltaWasteGate
I know every ones response will be "Dump the Delta and get a Tail". But I have the Delta, but for some reason or another I only hit 5psi.
I turned the screw on the top to make it run more psi but it dosen't seem to work.
Do I need to get in at the spring to adjust it?
if u screw the bolt down in further, it will hold out til a stronger psi - watch ur boost gauge carfully, and listen to when it cracks open.....down - more boost, up - less boost.
vg7z
Sep 20, 2006 08:27 PM
SOHC_MShue
Mar 14, 2005 03:00 PM
