Deltagate Wastegates?
Old Dec 2, 2001 | 08:48 PM
zojirushi's Avatar
Default Deltagate Wastegates?
Are they really that bad. I've read some posts where ppl tell others to get rid of the deltagate for a tial. ??? any suggestions?
Old Dec 2, 2001 | 09:10 PM
DamonBoost's Avatar
New User
Default Re: Deltagate Wastegates? (zojirushi)
I got one I will sell you for $50
Old Dec 2, 2001 | 09:32 PM
captain4g63's Avatar
yep they are crap, it will last about 6 mo. I've gone through 3. The seals go out and the valve shaft breaks. I switched to a 40mm tial. I have 2 good, rebuilt, Deltas... for sale
Old Dec 3, 2001 | 04:24 AM
4dGSR at work's Avatar
Default Re: Deltagate Wastegates? (captain4g63)
delta's are ok... i wouldnt trust it over 9 psi
i got a 2 month old one if you want for 50 beans too.....
IM me if you want it
Old Dec 3, 2001 | 05:51 AM
rtype11's Avatar
I understand that the major factor for deltas failing is any install whereby the valves stem angle is not at a 90 to the ground, right side up or inverted. the valve does not open and close properly. I have devised a guide that keeps the valve stem centered and eliminated all failures (except the odd diaphragm rupture)
Old Dec 3, 2001 | 06:37 AM
D-Man's Avatar
Default Re: Deltagate Wastegates? (rtype11)
No Problems with my Deltagate,been running 2 years now,30,000 miles on it,boosting between 9-13psi with the black spring installed in it,i think most of the problems you hear about deltagate's are cause by the owner! morons running extreme EGTs,cooking thier deltagates which in turn causes the valve inside it too stick.
[Modified by D-Man, 3:38 PM 12/3/2001]
Old Dec 3, 2001 | 07:53 AM
zojirushi's Avatar
Default Re: Deltagate Wastegates? (D-Man)
Is there a problem with boost creep with these wastegates? Does the tial control boost creep better?
Old Dec 3, 2001 | 07:58 AM
rtype11's Avatar
boost creep is a result of the exhaust pulse and pressure and ability of manifold and exhaust to flow properly, all WG are desgned well, it is a very simple product, failures to keep boost in or bypass properly are because of improper install / application. if you have a lot of creep your car flows too much CFM, go to a race gate etc.. get bigger exhaust, or your EG is mounted not on a central primary collector and just on one primary.
Flr Power
Nov 10, 2017 05:38 AM
artie89
Apr 22, 2015 09:20 AM
4dek
May 27, 2008 10:55 PM
90sedan
Jun 11, 2007 10:02 AM
ezark
Oct 2, 2002 12:34 PM
