Delta 272-2 cam
Old Mar 28, 2013 | 06:27 PM
HONDATAD16's Avatar
Default Delta 272-2 cam
I have d16y7 block with d16z6 head. I blew head gasket and removed head to take to machine shop to have checked. head needed to be machined 8 thousands for a flat deck surface. when machine shop removed cam and rockerarms. 4 of the rollers that keep rockerarms aligned on intake side are missing. I didnt build the engine, bought in car. where can i get the rollers, i have searched with no luck? car ran fine but i feel rollers have to be there for proper valve train alignment.The rollers are missing from long rocker arms that go to intake valve. other intake side rockers have the rollers.
Old Mar 29, 2013 | 04:58 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Delta 272-2 cam
What are you calling rollers?
http://www.hondaautomotiveparts.com/...ER+ARM+%282%29
Also, what in the hell does this have to do with Forced Induction?
Old Mar 30, 2013 | 09:49 PM
HONDATAD16's Avatar
new to forum where should i have posted this in tech/misc? in the rocker arms on intake side are round solid metal pieces which keep rocker arms aligned with valve. head is d16z6 vtech. Does anyone still sell these not available from dealer? Dealer only sells complete rocker arms which are also discontinued. Thanks
Old Mar 30, 2013 | 10:29 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
this should be posted in the civic forum
Old Mar 31, 2013 | 05:40 AM
DO IT ON ALL FOURS
Did you even click on the link I gave you? THEY ARE STILL AVAILABLE! I gave you part numbers AND prices. What more do you want? They are called collars and could be called spacers if needed. You may have to get off your butt and actually try something, you can't get them off eBay or Amazon...
Old Apr 5, 2013 | 08:58 PM
HONDATAD16's Avatar
Thanks for link. I went to local Honda dealer first, part discontinued by honda. Also tried to search with google, had no luck. I'm new to Honda thats why I ask here.
Old Apr 6, 2013 | 03:41 AM
DO IT ON ALL FOURS
Most likely they had no clue what you were asking about and just told you they were discontinued. If they truly are, then it is time to hit the junkyard and preferably just get a different complete head. Being "new to Hondas" isn't an excuses for not having common sense.
new_climber
11
Jan 15, 2009 07:48 PM
PA MATT
Mar 13, 2007 12:40 PM
e jay one
Jan 27, 2007 04:40 PM
96_teck
Mar 12, 2005 07:06 PM
blackeg
Dec 30, 2003 11:00 AM
