Decision: What should i do???
Old Jun 8, 2004 | 02:08 PM
StolenTeg's Avatar
Default Decision: have greddy kit+t3/t4 turbo i piece myself What should i do???
Modified by StolenTeg at 2:53 AM 6/10/2004
Old Jun 8, 2004 | 02:17 PM
so simple's Avatar
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (StolenTeg)
since your not in cali, you can upgrade a lot without worrying about smog legality etc, so you can pursue the upgradable path, the greddy is mostly practical in cali where it has strict laws. so you can sell it to me! PM me or email at simpleaznx@yahoo.com if youre interested
Old Jun 8, 2004 | 02:25 PM
StolenTeg's Avatar
The Car
The Greddy Turbo:
My Turbo:
*Actual item that seller show but isnt here yet LOL*
Modified by StolenTeg at 11:43 PM 6/8/2004
Old Jun 8, 2004 | 03:16 PM
StolenTeg's Avatar
how much Whp can the 18g turbo hold???
Old Jun 8, 2004 | 04:09 PM
Adriano's Avatar
It depends how much power you want. If you want a nice and simple kit (very good quality) which will give you some decent power, i would keep the greddy. if you want something more powerful and more compicated (instalation wise), i would keep the other one you are piecing together.
Old Jun 8, 2004 | 07:08 PM
Turbocivic94's Avatar
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (brryder)
Greddy kit, u install it and forget it
I would keep ur kit cause u can always make more power with ur kit
Old Jun 9, 2004 | 03:03 AM
StolenTeg's Avatar
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (Turbocivic94)
Is it possible to be able to pump out 300whp in the greddy 18g turbo?. That my power gold. will be tuning with hondata.
Old Jun 9, 2004 | 03:14 AM
jDMJeRk's Avatar
Id look into bracin that manifold....If you havent already you should. Its called autocrome or something....I dont remember the POS's name; they break very easy because of how heavy the turbo/waste gate is...
Old Jun 9, 2004 | 04:32 AM
StolenTeg's Avatar
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (jdmjerk)
I've decided that i will be using the greddy kit and the intercooler that i brought, and used the greddy blue box for 1-2 month and convert to OBD1 and hondata tuned it. im hoping once it all tuned and everything it would make 280-320whp maybe on 8 psi? what i've heard is that the 18g turbo max out at 300whp? is that true? and how much power can the 310 injector flow up too, im thinking i need to get something like 550.
Old Jun 9, 2004 | 05:45 AM
TurboBumblBee's Avatar
what type of motor work do you have done to the car already? im not sure those numbers are possible on a stock ls.. i would say your looking closer to 200-220 maybe with good tuning w/ that 18g turbo.. get yourself a nice t3/t4 and you will make 300 a lot easier
thats a drag kit and hondata...
Old Jun 9, 2004 | 05:51 AM
m R g S r's Avatar
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (Boostfedb18c1)
NO WAY your gonna get 280-320whp on 8psi with the greddy kit and upgraded FMIC. Unless your running some kind of rediculous compression ratio, a stock LS motor won't make those numbers.
Old Jun 9, 2004 | 07:03 AM
LudaMan's Avatar
Look what I can do!
Default Re: Decision: have greddy kit+t3/t4 turbo i piece myself What should i do??? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">Id look into bracin that manifold....If you havent already you should. Its called autocrome or something....I dont remember the POS's name; they break very easy because of how heavy the turbo/waste gate is...</TD></TR></TABLE>
Its called SS Autochrome. P....O....S....... yeah one of my friends bought one and it cracked severely two days later
Old Jun 9, 2004 | 07:28 AM
SIK IN DA HED's Avatar
New User
if you want some real power and a good kick in the ***.. keep your kit.
Old Jun 9, 2004 | 08:57 AM
mamaboy's Avatar
sell your greddy kit. use the money to get better parts. sell your manifold and get yourself a simple inlinepro mani. get a bigger intercooler. sell your intercooler, manifold, and your greddy turbo kit. with that money you should be able to piece together a simple setup that can probably yield you those hp levels. get larger injectors and don't run this thing until you have everything....esp. your fuel management. if your converting to obd1 hondata is a very very affordable solution.
Old Jun 9, 2004 | 10:51 AM
roydogg's Avatar
http://www.boosted-hybrid.com/viewtopic.php?t=28
http://www.boosted-hybrid.com/viewtopic.php?t=86
mugenNR10
Mar 23, 2006 12:37 AM
intekragsr
Jun 3, 2005 02:48 AM
ozzyman
80
Jan 13, 2004 09:16 AM
intekragsr
Apr 6, 2003 06:23 PM
HybridKOOP
Oct 16, 2002 06:36 AM
