Decided to build the D16
Old Jun 22, 2003 | 10:16 PM
M.A.R.C.'s Avatar
Default Decided to build the D16
Well all, tonite I decided I'm gonna go for the bottom end of the motor next. No... nothing catastrophic has happened YET. But I was back to boosting 8-9psi and I loved it. But I thought two things. Rods and pistons is more assurance, and... IMAGINE 12-14psi! muahahaha. Anyway I don't think I'm going to sleeve the block. Not 100% sure, but most likely not. Now, I haven't done much research on piston choices, but rods I'm pretty sure Eagles will be fine. I hear from a few that SRP pistons aren't a good choice for some reason or another. Wondering what pistons other D16 turbos are running, or a good recommendation. Right now I'm thinking Wiseco, CP, or JE's. I'm thinking 9:1 compression. Also, is there any other recommended work to be done while slapping in the rods n pistons? Also for anyone who would ask, I'm aiming for anything over 250whp for now which shouldn't be too hard, but I don't wanna AIM too high and be disappointed when I do the work.
Old Jun 22, 2003 | 10:36 PM
Drew Peacock's Avatar
Default Re: Decided to build the D16 (CivicRyda2k)
Eagles and SRP's 9:1 are what I am considering I hear the SRPs are a good quiet piston.... I am going to shoot for 300whp@20psi with Race gas at the track Sorry can't really help
Old Jun 23, 2003 | 02:51 AM
cajnatc's Avatar
Default Re: Decided to build the D16 (turbozxi)
I'm running eagle rods with arias 9:1 forged pistons in my D16Y8.
Old Jun 23, 2003 | 03:58 AM
spectunedphil's Avatar
marc,
eagle & JE pro series forged 9:1 pistons
crower & endyn pistons(if you feel like ballin')
btw,,i still cant make any pwer past 6k
Old Jun 23, 2003 | 06:37 AM
VTC_CiViC's Avatar
Default Re: Decided to build the D16 (hondadriven)
Something about the high silicone content in SRP's that makes them undesierable for high boost aplications.. can't remember off the top of my head.
Old Jun 23, 2003 | 06:38 AM
M.A.R.C.'s Avatar
going with eagles and something hehe... just gotta research pricing
Old Jun 23, 2003 | 06:46 AM
TurboJesse
Guest
Posts: n/a
you still gonna run the same turbo marc?
Old Jun 23, 2003 | 06:50 AM
M.A.R.C.'s Avatar
Default Re: Decided to build the D16 (VTC_CiViC)
btw dave u gonna sell me those rods?
M.A.R.C.'s Avatar
Default Re: Decided to build the D16 (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">you still gonna run the same turbo marc?</TD></TR></TABLE>
t3/t04e 46 trim
Old Jun 23, 2003 | 07:30 AM
ill_take_one's Avatar
I think you are making a good decision to build up the SOHC! I am going the same route as you, but will be sleeving my spare block in the next couple months.
I think you'd be fine with the SRP's, as long as you don't run HIGH boost.
What are you're goals for the car - horsepowerwise?
Goodluck!
Old Jun 23, 2003 | 08:36 AM
M.A.R.C.'s Avatar
Default Re: Decided to build the D16 (ill_take_one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one &raquo;</TD></TR><TR><TD CLASS="quote">I think you are making a good decision to build up the SOHC! I am going the same route as you, but will be sleeving my spare block in the next couple months.
Goodluck! </TD></TR></TABLE>
I have a spare block, but it's BARE... no crank. and I dunno if i want to try to afford the extra $$$. I'm looking for about 250-300whp (max)
Old Jun 23, 2003 | 09:12 AM
turbo sol's Avatar
i have srp 9:1's and the engine sounds god. havent got to boost on it yet but i have got over 1,000 miles on it.
I plan on boosting around 12psi srp's and LS rods. we'll see.
Old Jun 23, 2003 | 09:28 AM
Pengo's Avatar
Default Re: Decided to build the D16 (turbo sol)
are most of you guys running stock bore pistons or oversized? also, does the block have to be notched for all aftermarket d-series rods? just tryna get an idea of how much machine shop work has to be done. if there's anyone with stock bore pistons and rods that dont have to be notched for, has anyone attempted to do the work themselves? what other basic parts (bearings, seals) should be replaced while building u the block? thanks
Old Jun 23, 2003 | 09:31 AM
Infinity_Racer's Avatar
i'm going to bulding up my d16z6 as soon as i can get this d15 dropped in...i'm in the same situation as you (looking for rods/pistons)...now you guys know about turbopanda's toyota pistons with b16 rods...i know the block needs to be notched, but do LS rods fit in the d16? was it the ls or the old d16 integ motor? couldnt you use those and mate it to the toyota piston and not have to worry about notching? i was just thinking about it because i wasnt sure...anyone know
p.s. you should make sure to keep a log and keep us updated on how the progress is...good luck
Old Jun 23, 2003 | 11:40 AM
Default Re: Decided to build the D16 (Infinity_Racer)
Check out this link has some decent info about the varying brands of pistons
http://www.g2ic.com/forums/sho...stons
Old Jun 23, 2003 | 11:43 AM
RyanEJ8's Avatar
Default Re: Decided to build the D16 (Pengo)
I'm installing a set of Eagle rods and SRP 10.5:1 on my D16 right now. The block does have to be notched. There is some info on how to do it here. http://www.theoldone.com/artic..._tips/
It looks fairly easy and I will be doing it on Wednesday.
Old Jun 23, 2003 | 01:15 PM
oscarmayer's Avatar
I'm building a monster D16 motor. My goal is 500wheel power. that's 600 crank power. I'm goign to be running crower rods and Endyn roller wave pistons. I got the corwers for stupid cheep, but if I had not gotten them for so cheap, I would have gone with eagle rods.
Check them out. http://www.theldone.com
If you use their pistons and eagle rods along with a hondata ecu and 440-550 inhjectors, you'll be able to run 16-17 lbs of boost on that thing on pump fuel on the stock block w/o issues. Just needs to be properly tunned. that's about 290-320 wheel power. Give or take weather and tunner. That sound like fun?
Old Jun 23, 2003 | 01:17 PM
oscarmayer's Avatar
forgot to add
"t3/t04e 46 trim"
That's way too small. the exhaust should be a .48 and the compressor shoudl be a .60 with a .54 up to a .60. that will easly be able to grow with your car as you do more work. It is capable of producing 400-500 wheel power. make sure you get an oil and water cooled unit with a 360* bearing.
Old Jun 23, 2003 | 02:14 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
I have a spare block, but it's BARE... no crank. and I dunno if i want to try to afford the extra $$$. I'm looking for about 250-300whp (max)</TD></TR></TABLE>
I have a y7 crank in the garage...you pay shipping its yours.
liam
Old Jun 23, 2003 | 02:16 PM
liam821's Avatar
25 Year Member
Default Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">forgot to add
"t3/t04e 46 trim"
That's way too small. the exhaust should be a .48 and the compressor shoudl be a .60 with a .54 up to a .60. that will easly be able to grow with your car as you do more work. It is capable of producing 400-500 wheel power. make sure you get an oil and water cooled unit with a 360* bearing.</TD></TR></TABLE>
That turbo is a .48ar with a 46trim compressor. Its good for around 350hp. Its a really nice SOHC turbo. How do i know? That was my old turbo i sold it to marc. It will really nice for his goal of 300whp.
liam
Old Jun 23, 2003 | 02:24 PM
djdxm's Avatar
Finally Marc's gonna be a man!
I say Eagle rods and CP pistons and a GE block gaurd.
Jay
Old Jun 23, 2003 | 02:25 PM
djdxm's Avatar
Default Re: (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
That turbo is a .48ar with a 46trim compressor.</TD></TR></TABLE>
Thats a baby turbo! that thing can fit inside my turbos inlet... ok well maybe not.
liams turbo kicked ***.. was perfect sohc turbo.
jay
Old Jun 23, 2003 | 07:05 PM
turbo sol's Avatar
Default Re: (djdxm)
i went 10 over on the pistons to make sure everything was cleaned up when they bored the block. (after my block gaurd was in )
Old Jun 23, 2003 | 07:09 PM
liam821's Avatar
25 Year Member
Default Re: (turbo sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">i went 10 over on the pistons to make sure everything was cleaned up when they bored the block. (after my block gaurd was in )</TD></TR></TABLE>
I agree..this is a good idea...and a *REALLY* good idea if you are going to use a block guard..i wouldnt use a block guard unless i was going to bore/hone the block as after you install one it can push the cyl out of alignment (which will cause more problems then not having one installed in the first place).
liam
Old Jun 24, 2003 | 04:14 PM
M.A.R.C.'s Avatar
ok hows this sound:
CP .020 over 9:1 pistons
Eagle Rods
Golden Eagle Blockgaurd
The head I'm thinking to leave stock, not 100% sure but ill see. will have it resurfaced obviously.
