Debating to switch tranny from GSR to B16A?
Debating to switch tranny from GSR to B16A tranny?
Im topping out at the end of 4th gear at the end of the track. Would it be wise to switch to a B16 tranny, that would make me shift in 5th and be around 6.5k. Im also running on 25in slicks. What is everyone revving to with a B16 tranny?
Re: Debating to switch tranny from GSR to B16A tranny? (kazino42)
you never go into 5th gear at the track stay with the gsr if you topping 4th out
1000 posts bitchs
1000 posts bitchs
Are you having a traction problem in the first, second, third gears? It sounds like you're not hooking up hard enough.
Re: Debating to switch tranny from GSR to B16A tranny? (turtle-eg)
You are probably gonna have to rev higher. What is your rev limit set at currently?
