DD LS Turbo??
Old Mar 27, 2011 | 07:53 AM
HondataB18's Avatar
Default DD LS Turbo??
Im planning to go ls turbo really soon on my daily driven integra, built head, stock bottom for now, GSR Tranny, and a 50trim turbo. The block has about 170xxx miles on it. I want to know if i can drive it everyday to work, and still drive hard on the weekends without any problems, i drive from queens,NY to jersey everyday.
Old Mar 27, 2011 | 08:00 AM
HondataB18's Avatar
Default Re: DD LS Turbo??
anyone??
Old Mar 27, 2011 | 08:32 AM
bigD's Avatar
I dont think anyone could tell you there will never be problems, but if you have a healthy motor, use good products and get a good tune you will give yourself a great chance at having a reliable fun car for a long time.
Old Mar 27, 2011 | 10:16 AM
vtechjunkie's Avatar
What he said. It won't be cheap, but it is very possible.
Old Mar 27, 2011 | 01:07 PM
CEPerformance's Avatar
I have a 97 b18b1 with 275k+ that I daily drive with an Ebay kit.
to daily drive a cheap kit and get away with it you'll need....
1:quality hoses (not "jdm" oil lines.)
2:good oil and filtration
3il restrictor (to prevent blow turbo seals)
4:Sufficient fuel
also, make sure your motor is healthy, I dropped my oilpan and check for oil coking and burning, compression, leakdown etc.
I paid $560 shipped for the kit
plus $60 for quality lines
$150 for rc440's
and i got a BNIB walbro fuel pump for free.
I paid a total of $770
I'm tuned on Crome with 10PSI and the car has been beaten and driven for about 40k miles.
Old Mar 27, 2011 | 03:26 PM
HondataB18's Avatar
and all this time i thought i had high mileage^ lol, thanks for the info, ill def do a leak down test and a compression test
Old Mar 27, 2011 | 03:27 PM
HondataB18's Avatar
any pics of the setup? if u dont mind
Old Mar 27, 2011 | 03:35 PM
shocker911's Avatar
only way to get some real good info on your motor is to compersion test and a leask down test. if thoes tests come back bad then i wouldnt waste your time on it
Old Mar 27, 2011 | 05:08 PM
HondataB18's Avatar
and if they dont pass the test, what should i do to get it fix??
Old Mar 27, 2011 | 05:11 PM
HondataB18's Avatar
i might just end up sending the block to a machine shop and let em rebuild it, new bearings,new seal,new rods, pistons, rings, balance the crank, and give it a good hone, it should be safer right?
Old Mar 27, 2011 | 05:39 PM
johnsvrt's Avatar
If it doesnt pass the tests then you have to see where you problem lies most likely it will be your rings while your in there doing rings i would do brand new rod and main bearings to be safe for boost.
Old Mar 27, 2011 | 05:48 PM
HondataB18's Avatar
yea if im sendiing the block to get rebuild, im gona do everything one time, so i dont have to worry bout sending it back again
Old Mar 28, 2011 | 09:14 AM
I'd post pictures but i'm not proud of the way it looks haha.
It's a good setup, i haven't track-driven it yet but will soon.
on 195/50/15's with a perfect alignment i break traction 1st, 2nd, and 3rd in boost.
It's definitely a fun DD.
if your compression/leakdown results turn out bad it's valves/rings/headgasket that can be the cause.
sport injector
Oct 21, 2009 08:43 PM
JDM_CRX_PLEASE
Apr 30, 2007 06:04 AM
fickel_8
Nov 10, 2006 01:27 PM
integra81
Oct 29, 2001 12:27 PM
