Datalogging question-Uberdata-Laptop
Old Jul 3, 2005 | 01:18 PM
1995Ex_Sedan's Avatar
Default Datalogging question-Uberdata-Laptop
I will be using a IBM Thinkpad with win2k on it and uberdata. I am aware of how to chip and burn the chips with the chipburner. What I'm unsure of is the datalogging. What part will I need to do this? Does http://www.moates.com sell a cable specifically that will work with my setup? I'd like to datalog just a big before I install everything and see what it looks like at stock.
Thanks for your help.
Old Jul 3, 2005 | 01:29 PM
BlueShadow's Avatar
Default Re: Datalogging question-Uberdata-Laptop (1995Ex_Sedan)
The best thing to do is check out your nearest Radioshack and see if they have the Nokia cell phone data cable (3285/5185). It only costs $9-$11, and you can download the device drivers online.
http://home.mn.rr.com/keebler6....html
Old Jul 3, 2005 | 03:56 PM
Bump for Ideas. I like the serial port hes got listed on there too. I might try that. Looks a heck of alot cleaner.
Anyone have any thoughts?
Old Jul 3, 2005 | 04:01 PM
BlueShadow's Avatar
Default Re: (1995Ex_Sedan)
Well there's not many other ways to do it. Your choices are:
-cell phone data cable
-serial cable with MAX223
-superdroids cable
-moates.net hulog
Old Jul 3, 2005 | 04:04 PM
300whpOrBust's Avatar
Default Re: (BlueShadow)
http://www.stealthmodeperforma...e.htm
Stealthmode also sells one already setup for ya
Old Jul 3, 2005 | 06:43 PM
King Tut33's Avatar
I have both the BURN1 and the HULOG from Moates. I love them both and the HULOG is very easy to install and fully removeable once tuning is done. You just have to solder on one 4 pin header on the ECU.
Old Jul 3, 2005 | 07:24 PM
Do they provide you with the header? And how does it look all hooked up? Does the ECU have to stay open during tuning? Run out the side via a hole?
Old Jul 3, 2005 | 07:44 PM
HiProfile's Avatar
You'll be hard-pressed to find any of those $10 cables. ATM radioshack has a few cables with the pl2303 chip in it. One is for the kyocera se47. I tried another radioshack for I believe a diff nokia, same chip, and worked fine. Info for it is on uberdata forums (IIRC its the one that uses the brown, red & orange wires)
Old Jul 3, 2005 | 08:49 PM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Do they provide you with the header? And how does it look all hooked up? Does the ECU have to stay open during tuning? Run out the side via a hole?</TD></TR></TABLE>
Yeah they give you everything including the USB cable to hook to your laptop. I just keep the cover off the ECU while tuning with the cable attached to the 4 pin computer audio cable header. I'll take a pic of it installed on my ECU if you want.
1sikhatch
Dec 1, 2005 11:20 AM
johnclaunch
Apr 17, 2005 09:44 AM
