...DAP EK DD Build Thread...
Old Sep 14, 2011 | 08:59 PM
DaFredsta's Avatar
Default ...DAP EK DD Build Thread...
Picked up a clean shell from a buddy it's a 1997 ek hatchback, this is goin to be my second real build first was a 1994 si eg aka RedRocket...my goal for this car is around 550-650hp on e85 daily driven :p, I've been building this for the past 2 months, here are her specs...
Motor:
b16 golden eagle sleeved block bored to 84mm
9:1 je pistons, crower rods, arp everything, moroso 5.5qt oil pan
complete portflow head with crower valve train, tappered valve guides, crower stage2 turbo cams with cam gears, oem Honda timing belt, victor x intake mani, ge fuel rail,ge 84mm head gasket, arp head studs
Trans:
Gsr tranny with quaife LSD
cc stage5 4puck unsprung with x pressure plate
Turbo Kit:
spoolin aspec mani, pte6262 .82ar, tial 44mm mrv wg, tial q bov, custom pippin with dp and dump tube, aem wideband, pte 950hp fmic,hondata s300
Fuel system:
oem sumped tank, aeromotive eliminator fp -10feed-6return, aermotive fpr, id2000cc injectors
I'm sure I'm forgetting stuff this is all off the top of my head she should be fired up this coming weekend, schools been kicking my butt so I've been slacking on her...
When I got her
Old Sep 14, 2011 | 09:55 PM
JSTANOTHERHONDA's Avatar
Default Re: ...DAP EK DD Build Thread...
can't wait to see her run.
Old Sep 15, 2011 | 06:45 PM
DaFredsta's Avatar
Ha you and me both
Old Sep 28, 2011 | 08:08 AM
DaFredsta's Avatar
Some more work done, I've been super busy with med school...feedback is greatly appreciated :p
Old Sep 28, 2011 | 08:27 AM
kyden's Avatar
sounds like a great build, although i'd get rid of those cams.
Old Sep 28, 2011 | 08:59 AM
DaFredsta's Avatar
Thanks and what would you reccomend as far as cams? Some s2 pro1s?
Old Sep 28, 2011 | 10:24 AM
shawty22's Avatar
Daily driven with the exhaust out the hood. Classy! A buddy of mine makes 650 on stock gsr cams...itr cams would work well also.
Old Sep 28, 2011 | 10:43 AM
DaFredsta's Avatar
Lol cops don't really care about emissions in Reno,Nv
Old Jan 1, 2012 | 08:39 AM
DaFredsta's Avatar
Finally took her over the hill to get her broken in and tuned on the dyno, Took the car to my buddy Derek he owns Parris Engine Dynamics in Stockton,Ca...Had some issue on the dyno, word of advice don't go off tial's website for wg spring pressure I thought I had the 14.5 springs in but spiked well over 18psi around 7k rpm we then took the wg off put in two soft springs didn't go off by tial's website this time and it made 13psi off the gate and final psi ran was 25psi making 665hp400tq not bad for a b16a2 maybe once I get a built trans and a twin disc I'll boost more to hit the 700+hp mark untill then I'm sure the car will do justice :twisted:
second to last pull
Old Jan 1, 2012 | 08:42 AM
DaFredsta's Avatar
I'll post a full view of the graph once I get it scanned, overall I'm very happy with the tune and the build...
Old Jan 1, 2012 | 08:49 AM
crvtectim's Avatar
Very nice! So swapping to the softer wg springs eliminated the creep?
Old Jan 1, 2012 | 09:00 AM
DaFredsta's Avatar
Im running the 44mm mvr wg and went off their site for the 14.5 spring combo but on the dyno it spiked over 18psi and hit boost cut no problem(off the gate) since I'm running the mac solenoid, softer springs are for lower boost levels so we just put in the two softest springs hoping I'd be around 10-14psi off the gate once it was solved we then hooked up the mac solenoid to the hondata
Old Jan 1, 2012 | 11:17 AM
crvtectim's Avatar
So while it was on spring pressure alone, was it still creeping from 10-14psi? I'm running the same manifold with bad creep. :/
Old Jan 1, 2012 | 11:40 AM
H22AFerio's Avatar
nice numbers! I love how you ran your charge piping thats what I was gonna do with mine but I didnt know if it would work right haha do you have pics of how you rin the driver side behind the bumper?
Old Jan 1, 2012 | 12:27 PM
DaFredsta's Avatar
No creep at all off the gate only it was at 13psi I was sating that when I chosed the two softest springs I was hoping it would be around the 10-14psi range and it was at 13 solid no creep
at all reving to 9300.
Thanks and yes I'll take a pic and post it, Not one charge pipe blew off on the dyno or while driving it
Old Jan 1, 2012 | 03:06 PM
crvtectim's Avatar
Awesome, thanks for clarifying.
Old Jan 1, 2012 | 04:08 PM
boostinlow's Avatar
looking good!
Old Apr 12, 2012 | 11:54 AM
DaFredsta's Avatar
Originally Posted by boostinlow
looking good!
thank you sir...
Old Apr 12, 2012 | 11:59 AM
DaFredsta's Avatar
Got rid of the oem tank and replaced it with this beautiful tank...
Old Apr 12, 2012 | 12:02 PM
B16B Four Door's Avatar
That's nice numbers bro
slick1851
Jul 24, 2010 10:30 AM
slick1851
Jul 1, 2010 09:19 PM
slick1851
Jun 8, 2010 12:20 PM
wyte_rice
Apr 4, 2010 02:37 PM
ek9800
Mid-Atlantic (Sales)
36
Oct 14, 2005 09:23 AM
