Damn, Timing belt jumping
Old Sep 4, 2002 | 07:50 PM
Ri5e's Avatar
Default Damn, Timing belt jumping
Found out why my motor is making a loud rattling noise... I took off the valve cover.
Cranked the motor by hand...and what do you know, the timing belt is jumping
1 notch every time i crank it a few degrees. This rattling noise happened after I was boosting it hard on the highway.
Old Sep 4, 2002 | 07:51 PM
Kamin's Avatar
Default Re: Damn, Timing belt jumping (CRV Monster)
hope you didnt bend a valve
check your belt tensioner.
Old Sep 4, 2002 | 08:07 PM
Speed PHreak's Avatar
Default Re: Damn, Timing belt jumping (KAMiN)
Been there done that..turned out to be a f'd up set of cam gears. I'd suggest a new tensioner, stock cam gears, and a new belt for starters. Are you running upgraded springs?
Old Sep 4, 2002 | 09:50 PM
Ri5e's Avatar
Default Re: Damn, Timing belt jumping (clean_dc2)
****, somehow the tensioner untensioned. I set everything back to TDC and retorqued it to 40 ft-lbs is that enough?
Car runs fine now. ****, so close to bending valves.
Old Sep 5, 2002 | 05:07 AM
DR. ON POINT's Avatar
Banned
damn man u have been going through some **** last couple months......
by the way I got my turbo on
Old Sep 5, 2002 | 08:16 AM
DLB1994's Avatar
Default Re: Damn, Timing belt jumping (On Point EK!!!!!!!!)
did u get a turbo kit or go custom
Old Sep 5, 2002 | 12:22 PM
Banned
Default Re: Damn, Timing belt jumping (DLB1994)
custom and hondata, my hondata is acting strange though
Old Sep 5, 2002 | 12:23 PM
SIK IN DA HED's Avatar
New User
yeah you better get it fixed right away. i had the same problem. it shot my waterpump while it was makin all that noise, too.
Old Sep 5, 2002 | 12:50 PM
xrtdac
Guest
Posts: n/a
Default Re: Damn, Timing belt jumping (dlplayboy)
would bent vlaves cause the car to run shitty on 5 PSI. Meaning not letting the car generate more than 5PSI of boost as well as take a while to get to 5PSI????
Old Sep 5, 2002 | 12:52 PM
dustin's Avatar
Default Re: Damn, Timing belt jumping (xrtdac)
When you tension the belt, loosen the tensioner, then turn the cam gears as hard as necessary towards the back of the car to put all the slack back there, then tighten the tensioner bolt to 40ft-lb. I wouldn't go past 40, It'd be easy to strip that bolt.
Old Sep 5, 2002 | 01:00 PM
sgT's Avatar
sgT
Default Re: Damn, Timing belt jumping (dustin)
that should put all the tension to the FRONT and slack to the BACK right???
Old Sep 5, 2002 | 01:03 PM
dustin's Avatar
Default Re: Damn, Timing belt jumping (sgT)
Haha I'm stupid. I english speak well. Post done edited fixed good now. Thanks steve.
b16-ef-si
May 16, 2009 03:23 PM
eg6madness
Jan 28, 2008 07:41 PM
VSBB6
Aug 17, 2005 08:32 AM
VSBB6
Aug 13, 2005 01:17 AM
mtber
Aug 24, 2004 06:50 PM
