D16z6 with greddy kit, worth it or should it be swapped?
I got a friend that wants to run the greddy kit plus an intercooler, hondata dyno tuned. at 7 or 8 psi on a stock d16z6. He wants to at least pull 200 WHP out of the setup, but isn't sure what kind of numbers he will pull. If anyone knows, or has a similar setup, let me know. thanks in advance.
Re: D16z6 with greddy kit, worth it or should it be swapped? (94B18B1Teg)
swap it, i have the greddy kit and it's slow unless you get 200+whp. D16's just can't handle much power in stock form, rather pick up a cheap B18 and have 300whp year round
Re: D16z6 with greddy kit, worth it or should it be swapped? (Del_Slowest)
Or alternatively pick up some rods, pistons, bearings etc and have money left over for possible sleeving and do the same. Pick your poison.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">swap it, i have the greddy kit and it's slow unless you get 200+whp. D16's just can't handle much power in stock form, rather pick up a cheap B18 and have 300whp year round</TD></TR></TABLE>
last time i checked no B series has 300whp....
Re: D16z6 with greddy kit, worth it or should it be swapped? (JD95hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch »</TD></TR><TR><TD CLASS="quote">
last time i checked no B series has 300whp.... </TD></TR></TABLE>
Wtf? OPEN your eyes dude!
Aren't we in a f.i forum?
So i think the possibilities are endless.....IF u got the scratch..
Heh, to clear up the B series making power, there was a street driven GSR on here, with 620WHP, pump gas. Just a clarification. And the turbo I bought came off a 314WHP B16A. *shrugs*
Re: (Sinner)
boosting a B series wasnt mention you dumbfuks....it was boostin a D16z6...if he could afford the Bseries and a turbo then he wouldnt need to bother with the d16 would he??
he would have just said...should my frined boost his d16...or buy a bseries and boost it.....cmon guyz...
i know a boosted DOHC can put out mad power...that wasnt my point.
Re: (JD95hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch »</TD></TR><TR><TD CLASS="quote">boosting a B series wasnt mention you dumbfuks....it was boostin a D16z6...if he could afford the Bseries and a turbo then he wouldnt need to bother with the d16 would he??
oh, in that case boost that bitch till it blows and then go crying to your mommie when it blows and ask for a B series. Thats what i would do ( if my parents actually gave a rats ***)
Seriously though, i'd turbo it if i were him. a swap is just too expensive unless you know ppl who can hook you up.
Re: D16z6 with greddy kit, worth it or should it be swapped? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">No need to swap, especially with a goal of only 200whp.</TD></TR></TABLE>
I second that full Trottle!
Kranked
Kranked
Not to be a *****.. but if you can't get over 200WHP out of a F/I D-16...... please pay someone else to work on it.
Oh as for the swap.. you cna drop in forged pistons and rods in a D-16 cheaper than you can do a swap.
Ditto to that!
Man d16 can hold their ground. No need to swap. the Greddy kit is ok for a 1st time boost owner. keep it under 8psi daily driven and it should last you a while (2-3years when tuned) I'd feel confident pushing 10psi but only on certain occassions.
7-8psi expect numbers of about 185wpish and 170tq
Ditto to that!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">D16's just can't handle much power in stock form</TD></TR></TABLE>
You sure about that?
https://honda-tech.com/zerothread?id=821860
Tuned right they can.
Re: D16z6 with greddy kit, worth it or should it be swapped? (infinatenexus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">
Oh as for the swap.. you cna drop in forged pistons and rods in a D-16 cheaper than you can do a swap. </TD></TR></TABLE>
Anyone can get over 200whp out of a D16, you just turn up the boost (it'll blow, i don't care who says that D16's are strong. I've seen my pencil dick rods and i just don't trust them past 200whp) And how much did you pay for ur swap b/c a build up costs around 2000 and you can swap in b16's now for around 1500 or less.
Anyone can get over 200whp out of a D16, you just turn up the boost (it'll blow, i don't care who says that D16's are strong. I've seen my pencil dick rods and i just don't trust them past 200whp) And how much did you pay for ur swap b/c a build up costs around 2000 and you can swap in b16's now for around 1500 or less. </TD></TR></TABLE>
See above.
Tuned properly, they can last a very long time and put out good power.
For a build you need about $1500 total for pistons, rods, machien work, bearings, etc.
Swaps cost a heck of a lot more than that in the long run if done right.
See above.
I see your point.. but if your doing a swap.. why waist 1500 on a B-16.. when a D-16 with pistons and rods will generate the same, if not more WHP for less money?
Just to let you know, I am in the process of building a D-16 with CP pistons, eagle rods, and an assortment of other goodies.. and I have yet to break the 2000.00 mark.
Boosted SOHC..... Anyone running boosted jdm D's?(ZC, D15b) Im still debating whether to get JDM D over D16z6 cuz i cant find them anyone in one piece with less than 100K miles
dont mean to ***** this thread but its sorta on the same topic.
Re: D16z6 with greddy kit, worth it or should it be swapped? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
That's exactly what my D16Y8 build cost, and it should be capable of safely producing more power than a stock B16 ever would.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch »</TD></TR><TR><TD CLASS="quote">Anyone running boosted jdm D's?(ZC, D15b)</TD></TR></TABLE>
Ill let you know this weekend.
And read this before your criticize SOHC's.
http://www.turbod16.com/viewtopic.php?t=4140
Re: D16z6 with greddy kit, worth it or should it be swapped? (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Ill let you know this weekend.
http://www.turbod16.com/viewtopic.php?t=4140 </TD></TR></TABLE>.
lol....i look at that all the time cuz im lost if i should go custom or greddy. but i see these greddy boosters puttin out 200+ whp on 10psi and it makes me wanna run greddy! but i cant decide!!
For one, it puts a cieling on your build. If you build and boost it and youre still not happy your **** outta luck, and a pretty penny. However if you swap a b16, it will be pretty nice, boost it, alot of fun, build it, amazing.
But I might build a ZC myself, heh.
But I might build a ZC myself, heh.</TD></TR></TABLE>
A D16 with the right forged internals can go 400-500+whp, that's gives a big ceiling to grow if you ask me. Displacement is the big limiting factor, which the B16 also lacks.
