D16Z6 Engine Build sheet
Old Jun 17, 2010 | 06:27 PM
boostedEGD16Z6's Avatar
Default D16Z6 Engine Build sheet
Just wanted to throw up my build sheet see what people think it will make. Its Just a DD so im not trying to break any records here HAHA.... just looking to see what you guys think it will make.
Engine:
YCP Vitara Pistons
Eagle Rods
Balanced and Polished Crank
Calico Coated ACL Race Bearings
ARP Headstuds
Supertech Valves, Springs and Retainers
Zex 59300 Cam
Precision 680cc injectors (yea there on the large side)
Golden Eagle Fuel Rail
Aeromotive FPR
Oem Head Gasket
Walbro 255
SPA Top Mount Manifold
Precision 6262 billet wheel T3 Journal Bearing
38mm Tial Wastegate
HKS Super Sequential BOV
Precision air to air intercooler
Blox manual boost controller
Speedfactory 4bar map sensor
Competition Clutch stage 5 clutch
2qt. Catch can
Transmission S40 (96-00 EX)
Mfactory Helical LSD
Mfactory 3.083 1st gear and 1.565 3rd gear
Mfactory 4.7 final Drive
Synchrotech Bearing,seal and carbon synchro kit
Synchrotech Differential bearings
DriveShaft Shop lvl 2.9 axles
So there it is any comments are welcome like i said not trying to break any records just something for a fun DD... any guess's on how much power it will make?
Old Jun 17, 2010 | 09:55 PM
neek175's Avatar
Default Re: D16Z6 Engine Build sheet
Looks like a good setup. Post some pics if you can. The final drive is going to shorten you at the track though.
Old Jun 18, 2010 | 06:36 AM
joe111599's Avatar
Pics!!!
Old Jun 18, 2010 | 10:54 AM
ill try to get pics asap according to the gear calc. i should be like 180mph at 8800 so i dont think it will be to horrible mostly gonna be a DD
Old Jun 18, 2010 | 07:47 PM
willyboyK20's Avatar
I would swap out the eagle rods for the custom rods from fjt just so your pistons wont sit below the top of the deck. I would also go with the ID 1000's instead of the 680's.
With that setup, you should be pushing mid to high 400's
Old Jun 18, 2010 | 11:36 PM
joe111599's Avatar
^^^True...I didn't see that earlier but 680cc is not really all that big of an injector. I would go at least 880cc or the ID1000's like dude said above.
Will definitely be pushing 500whp with a good tune.
bex3m
Sep 13, 2012 09:16 AM
sohcturbo92vx
May 24, 2012 07:19 AM
phelpsj2
Jul 11, 2010 10:25 AM
zachsboostedD
Dec 12, 2009 07:35 AM
mike93boost
May 31, 2006 04:15 PM
