D16z6 boost?
Old Aug 8, 2007 | 05:38 PM
killerB16A's Avatar
Default D16z6 boost?
ok i have a d16z6 with about 100k on it.......i am putting a new head gasket, apr head studs, new oil and water pumps.
what kind of boost could i safely run? 15psi? or is that a bit much. and i have good compression across the board.
Old Aug 8, 2007 | 05:43 PM
urbansi's Avatar
Default Re: D16z6 boost? (killerB16A)
Leave your power levels to a competant tuner, they should no when to stop and what the limits are of your motor... Honestly on a healthy d16 you should be able to see 200whp with out much trouble depending on you turbo setup and such, the tune will be everything...
Old Aug 8, 2007 | 05:52 PM
killerB16A's Avatar
Default Re: D16z6 boost? (urbansi)
the engine is in my friends car now and its stock turbo.....its at 180whp now at 8psi. so what i want to know is that when i put better head studs and a new head gasket can i run more boost?
Old Aug 8, 2007 | 05:55 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a d16z6 with about 100k on it.......i am putting a new head gasket, apr head studs, new oil and water pumps.
what kind of boost could i safely run? 15psi? or is that a bit much. and i have good compression across the board.</TD></TR></TABLE>
how much psi is not what you should ask, how much power you looking for? like killer16a said about 200 whp is the limits of a healthy d16 i assume you changed the timming belt too right.
urbansi's Avatar
As far as i know the stock head bolts should be able to support well over 200whp, i know on b series motors they can handle 350whp+ but i would not suggest it.
If you are dead set on doing headstuds then go for it, and do a timing belt and replace the pumps as well.
Old Aug 8, 2007 | 07:33 PM
killerB16A's Avatar
timing belt has been replaced a few thousand miles ago and is good. for me to get 250whp i would need to do some internal work i assume....
Old Aug 8, 2007 | 09:38 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">As far as i know the stock head bolts should be able to support well over 200whp, i know on b series motors they can handle 350whp+ but i would not suggest it.
If you are dead set on doing headstuds then go for it, and do a timing belt and replace the pumps as well.</TD></TR></TABLE>
Regardless of what the stock head bolts support, 220whp is about the safest power you will be able to make on a stock D16z6...assuming its healthy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">timing belt has been replaced a few thousand miles ago and is good. for me to get 250whp i would need to do some internal work i assume.... </TD></TR></TABLE>
You COULD make 250whp on a stock block, however to be safe I highly suggest you do not exceed 200whp. A great tune is key, and if you would like to make more power, take your time and build the block.
Old Aug 8, 2007 | 09:44 PM
killerB16A's Avatar
Default Re: D16z6 boost? (1995Civic)
i know i should build the block. with that said i am trying to find easy hp thats all. now what if i put a skunk2 stage 1 cam in it or maybe a stage 2 in it? would t his help?
sorry im just trying to get as much hp with out tearing into the block at this time.
Old Aug 9, 2007 | 09:35 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">i know i should build the block. with that said i am trying to find easy hp thats all. now what if i put a skunk2 stage 1 cam in it or maybe a stage 2 in it? would t his help?
sorry im just trying to get as much hp with out tearing into the block at this time.</TD></TR></TABLE>
How much whp are you looking for now?...just so were on the same page here.
Old Aug 9, 2007 | 10:39 PM
killerB16A's Avatar
well i would love between 225whp and 250whp.
Old Aug 10, 2007 | 09:33 AM
slodel's Avatar
whats your compression
i have over 220,000 miles on mine at 10lbs
my compression is low though 145 across the top
Old Aug 10, 2007 | 09:46 AM
Schister66's Avatar
Man U FTW
boost doesn't mean ****...power kills engines
most people agree that to keep a D "reliable" stay under 220whp on a stock bottom end
Old Aug 10, 2007 | 06:38 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">well i would love between 225whp and 250whp.</TD></TR></TABLE>
To be safe....I wouldnt.
Its definitely possible, but dont chance it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">boost doesn't mean ****...power kills engines
most people agree that to keep a D "reliable" stay under 220whp on a stock bottom end</TD></TR></TABLE>
Amen.
Old Aug 11, 2007 | 11:40 PM
killerB16A's Avatar
k cool thanx for the info ill keep it at 200
EG Boostin
Feb 8, 2007 01:49 PM
delsoldrew
Mar 13, 2006 12:29 PM
alexsracing
Nov 30, 2004 07:07 PM
99lspwr
Oct 3, 2004 05:33 PM
td04civic
Feb 25, 2002 09:21 AM
