D16Y8 Turbo Built
Old Nov 27, 2011 | 07:25 PM
  #26
phat00civic's Avatar
Default Re: D16Y8 Turbo Built
I run this mani and had no issues
http://www.pfabrications.com/inc/sdetail/258
I did remove my AC though because the way the 15G sat and the downpipe would not clear unless I had another downpipe made. This was more of my issue then the mani though. They do sell others, but if you call them they are great.
Old Nov 27, 2011 | 08:34 PM
  #27
m0sad's Avatar
Originally Posted by MalcolmV8
I was thinking fine dust that's gonna eat away at your rings/pistons and what ever else in the engine.
My manifolds from left to right
Spoolin Performance
Ebay special
go autoworks
go autoworks
I believe the first and 4th ones are indeed stainless. Center two are cast.
I'm talking about the spooling performance, I saw it in their website, they asking 650$! that is the same price like here.
Your prices (USA, Europe) are usually cheaper from here.
Originally Posted by sde780
Yup, 3rd gear. I'd go 3" for better spool, originally wanted to keep a/c but that didn't work out
I used Crome, but I hear Neptune is better. Or if you're baller go Hondata.
I thought to use a 3' but i already bought a friend's 2.5' maybe later i will change it.
i'm keeping the A/C, in the future i'll mount it back.
Hey MalcolmV8, why don't you install the turbo backward ?
i mean that you put the EXT close to the tranny, and the intake close to the timing.
(sorry about my poor english...)
Old Nov 27, 2011 | 08:51 PM
  #28
MalcolmV8's Avatar
Yup it's the Quick 4 AC unit. $650 plus shipping for it. Since I'm not using it I'll let it go for $450 if someone wants it.
Humm I'll try that. I know I tried it on some of the other manifolds and it didn't fit. I'll try on this latest one I'm using and see how it fits.
Don't worry about the english man, you're doing great. I know we'd all struggle in another language.
Old Nov 28, 2011 | 05:02 PM
  #29
EsotericImage's Avatar
Retired Moderator
the dust and dirt will damage the blades of the turbo. Its called "dusting"
i dont even want to point out the irony here
Old Nov 28, 2011 | 09:43 PM
  #30
m0sad's Avatar
Thx man, but still to rich for me at the moment, only the shipping is gonna kill me [=
anyhow, if you flip the turbo and of course change the DP, i'm sure it will fit!
anyway,
got my clutch yesterday ,
took a stage 4 "Clutch Net" clutch.
and trying to find a nice wastegate or a 3 gauge combo to buy.
if you guys have any suggestions please tell me.. [=
Old Nov 30, 2011 | 12:12 AM
  #31
BuiLt Gsr's Avatar
hey bro when you installed the pistons and rods, did you need to grind or something the cylinder to make it fit with the eagle rods.. bcoz im gana build my motor too.. thanks
Old Nov 30, 2011 | 02:24 AM
  #32
m0sad's Avatar
Hi man,
Yes I did. like you see here (if you zoom in ) you will see that i grind the bottom (front and back) of the block and the "bridge" that comes on the crankshaft (dont know how it's called in english.. but you see theme both in this pic..
Best of LUCK.
anyway, i ordered my Defi Boost&EGT gauges today
and my friend from the US will send me a TurboSmart 38mm Wastegate.
Wideband i'll an AEM one, and all that is left to do is to wait for my dear friend #Racepak to make me a miniram manifold...
Old Nov 30, 2011 | 06:45 AM
  #33
sde780's Avatar
with Eagle rods you need to notch the girdle, with fjr i-beams some people have gotten away with notching just the block
Old Nov 30, 2011 | 06:55 AM
  #34
scottdh20's Avatar
i am using a prelude slave cylinder on mine works just fine....you just need to hog out one hole about 1/8 of an inch....gave me the clearence to stuff an hx35 down in the engine bay....
also i have aluminum window screen doubled up over the turbo inlet....it would not be possible for me to make an intake....i thought about the flexable dryer hose but the way it sits in there i would have to compress part of it and i was worried in higher rpms that it could colapse it and then suck it in
as for gauges if your boosted you NEED a wideband, oil pressure, and boost gauge at minimum, i also tossed on a water temp gauge for safe measure, you have no idea how many times my stocker said i was fine and i look and im at 220f
Old Nov 30, 2011 | 08:14 PM
  #35
m0sad's Avatar
my top priority is boost, egt and widebend.
after that i'll add an oil pressure one.
this week i hope to install the engine.. (:
Old Dec 1, 2011 | 01:21 AM
  #36
RACEPAK's Avatar
Looking good,
but.... building a engine outdoors never helped
NVM. i'm sure my manifold wil make up for all this
Old Dec 1, 2011 | 01:25 AM
  #37
m0sad's Avatar
next time i'll build a sealed room like a bunker, like yours (:
Old Dec 1, 2011 | 01:37 AM
  #38
m0sad's Avatar
and also we needed some fresh air.. (:
Old Dec 3, 2011 | 11:27 PM
  #39
m0sad's Avatar
OK, yesterday I installed the engine.
OEM tranny oil
a regular engine oil (preston 10-40) and a 5$ oil filter just for the first 1000km that will grab all the dirt.
after that i will change it to the good stuff.
and must give my dear friend Eliran (6 pic) that Replaced the oil dipstick location (ZC oil pump ) and for ALL the help (:
next up is adjusting the FMIC piping and cutting the F-bumper so the cooler will fit.
that's all for now, will keep updating
Old Dec 4, 2011 | 01:52 AM
  #40
RACEPAK's Avatar
r u fo real? replacement oil filter?
Old Dec 4, 2011 | 02:44 AM
  #41
m0sad's Avatar
YEP!!! the best way to go 1000km
Old Dec 4, 2011 | 04:13 AM
  #42
sde780's Avatar
Looking good! I'm building my motor outside too :D you can't make good power without dust!
Old Dec 4, 2011 | 08:30 PM
  #43
m0sad's Avatar
dust or no dust, the engine work's and run perfectly fine.
you do not need a lab to close an engine.
Old Jan 1, 2012 | 10:21 PM
  #44
m0sad's Avatar
Hello,
finished my 1000km run, replaced the oil with Agip oil 10-60 fully synthetic, and to a OEM pil filter.
now waiting until my fabricator will make me a mini-ram mani, adjust the downpipe, and that's it..!
Old Jul 24, 2012 | 10:49 PM
  #45
m0sad's Avatar
sorry for not updating for a long time..
my car now r tuned on only 16psi and have no traction on 3rd.. need better tires [=
will keep updating
m0sad
Feb 11, 2013 09:40 AM
Maines_Cleanest00
May 28, 2009 04:55 AM
slownsteadygetsunowhere
Apr 5, 2005 12:24 PM
SilverCivic2287
Nov 14, 2004 04:35 PM
mntdewred
Apr 15, 2004 04:40 PM
