D16Y8.... Stroker Kits?
Old May 23, 2007 | 03:43 PM
99EX12psi's Avatar
Default D16Y8.... Stroker Kits?
Anyone know if there are any stroker kits for these motors? If so, is it worth it?
Old May 23, 2007 | 04:14 PM
Spoonie09's Avatar
Default Re: D16Y8.... Stroker Kits? (99EX12psi)
from that frog company i forgot there real name
Spoonie09's Avatar
Default Re: D16Y8.... Stroker Kits? (Spoonie09)
I remeber GUDE
Old May 23, 2007 | 04:30 PM
dr_latino999's Avatar
Worth it? No.
Old May 23, 2007 | 08:28 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99EX12psi &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know if there are any stroker kits for these motors? If so, is it worth it?</TD></TR></TABLE>
There are no kits that I'm aware of, but you could do your own. The D17 crank from the 2001-2005 Civic will fit the block, and with custom rods and pistons, you could up the stroke from 90mm to 94.4mm. Then if you went with a sleeved block, you could up the bore from 75mm to 78mm. That would get you a 1.8L D series.
If you wanted to rev it at all (above 7,500 rpm), you'd need to get a deckplate to improve the rod/stroke ratio. The math I did a while back led to approx. 1" deck plate to put the R/S at about 1.7:1.
Old May 24, 2007 | 02:12 AM
Legion's Avatar
* B A N N E D *
Default Re: D16Y8.... Stroker Kits? (Jaker)
A stroked D-series is the worst idea I've ever heard of.
Old May 24, 2007 | 09:26 AM
Jaker's Avatar
Default Re: D16Y8.... Stroker Kits? (Semtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Semtec &raquo;</TD></TR><TR><TD CLASS="quote">A stroked D-series is the worst idea I've ever heard of.</TD></TR></TABLE>
Would you care to explain your position on this?
Old May 24, 2007 | 02:02 PM
Legion's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Would you care to explain your position on this?</TD></TR></TABLE>
Worse r/s ratio, increased cylinder walk, lower redline... Not to mention a stroker kit costs about 5x as much as a d-series motor.
Why would anyone want a lower redline on a d-series? They already struggle to make power up to 8k.
Old May 29, 2007 | 08:44 AM
99EX12psi's Avatar
I figured it was more work than it's worth, might as well just do a complete swap. But it would be cool for me cause I would like to make the most power out of the D16 that I already have. The power is good in upper r's cause of the turbo, the low end is what I was worried about. Thanks guys.....
Baby99EX
Dec 28, 2016 06:49 PM
khmoe
Apr 27, 2011 10:17 AM
crx_crvtec13
Sep 15, 2004 06:00 PM
ace1875
Jan 9, 2004 02:46 PM
Spade
Oct 23, 2002 11:53 PM
