D16A6 Turbo
Old Apr 5, 2002 | 05:02 PM
89 CRX SI's Avatar
Default D16A6 Turbo
Hey guys I'm starting a Turbo setup on my 89 CRX Si. Presently its got a clean d16A6 engine with no mods. So far what i gather i need is:
Turbo
Turbo Manifold
BOV
IC Pipes
Intercooler
Oil Lines ( Copper )
Boost Gauge
EGT Gauge
Polyurethane clamps
Oil Line Fittings
Well do I need anyhting else to make this work. I'm using 2.5" mendrel bent boost tubes/Intercooler tubes. This should help reduce the lag. I have polyurethane clamps to attache them together. Then I will or someone will make me a custom turbo manifold.
Then I will run the oil return line into the oil pan like normal but where can I take oil from??? A sender???
If anyone has a manifold/Turbo or any of these parts e-mail me at: dohc16v@shaw.ca I have lots to trade and have money.
Anyone have info on turboing D16A6's or similar engines? or sites with info???
THX
[Modified by 89 CRX SI, 2:03 AM 4/6/2002]
Old Apr 5, 2002 | 07:37 PM
Smashback's Avatar
Default Re: D16A6 Turbo (89 CRX SI)
Check my site for what I did with mine. You'll probably want either 2 or 2.25 inch piping depending on what turbo you use. Mine is 2" and steps up to 2.5" about the last 2-2.5 feet before the TB.
Old Apr 5, 2002 | 07:46 PM
89 CRX SI's Avatar
Default Re: D16A6 Turbo (mplex2000)
THX guys keep em coming
deesixteen
Jan 25, 2007 03:24 PM
Honda Kustums
Jun 9, 2003 07:28 PM
OEMJDM
Jan 21, 2003 03:37 PM
89 CRX SI
Apr 6, 2002 07:56 AM
