D16A6 9psi JRSC w/stock injectors...?
I have been running this setup for the last 47K miles and it runs well with no problems. At 95psi of fuel pressure at 9psi boost there is a potential for a problem, but all has been well.
My question is... Is there more power to be had by going to larger injectors and an aftermarket ECU?
Re: D16A6 9psi JRSC w/stock injectors...? (Zeppelin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeppelin »</TD></TR><TR><TD CLASS="quote">I have been running this setup for the last 47K miles and it runs well with no problems. At 95psi of fuel pressure at 9psi boost there is a potential for a problem, but all has been well.
My question is... Is there more power to be had by going to larger injectors and an aftermarket ECU?</TD></TR></TABLE>
Using an aftermarket ecu and tuning would help you optimize a/f ratio and timing, I'd say that should produce more hp.
Not sure how much hp, never had it dyno'd. Just figured it would cost $1500 - $2000 for injectors/ECU/Tuning, there would have to be alot more hp on tap for me to invest that kind of money.
em1_sir
12
10-18-2007 08:01 PM
1SickHb
12-09-2005 08:13 AM
The-LS
05-01-2003 08:00 AM
