D16 turbo, over heating problems. Need some help/advice.
Old Aug 19, 2007 | 02:46 PM
Jwbetley's Avatar
Default D16 turbo, over heating problems. Need some help/advice.
I recently put a t25 turbo into my 89 civic wagon, 1.6 L d16a6 ( hf mani). As of right now, I have a blown turbo. In order to run the car, I removed the oil line to the turbo and charge pipes in to run N /A until I get receive my new 16g.
The problem... My engine is running very hot according to my autometer water temp gauge. It is running at 250F, even at idle. I do no know why. My guess is that because I am running exhaust through a seized turbo, the heat is being trapped in the head (where the temp sensor is).I did manually open the wastgate flange but the problem still persists. At 250F, I can easily remove the radiator cap without any pressure/ explosion. This makes no sense to me. I am running 50/50 pre-diluted anti-freeze.
I have no coolant leaks. I am running an after market aluminum (dual core) radiator. I removed my thermostat. My autometer gauge is hooked up to the temp sensor located underneath my distributor of my obd0 89 civic wagon.
Could the turbo, being so close to the radiator cause such a raise in temp? Could it be the seized turbo holding exhaust/heat in the head where the water temp sensor is located? Does auto meter make poor quality gauges?
Please help me.
-Justin
Old Aug 19, 2007 | 02:57 PM
DaveF's Avatar
Default Re: D16 turbo, over heating problems. Need some help/advice. (Jwbetley)
for the love of god, take the pos broken turbo off and put a stock manifold on there !
Old Aug 19, 2007 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: D16 turbo, over heating problems. Need some help/advice. (dturbocivic)
ok lemme get this straight.
no oil lines, no charge pipe?
well when that turbo finally s**t the bed and locked up, you now have a massive restriction in the exh. take the turbo off, put a new h.g. and some studs on the thing.
Old Aug 19, 2007 | 03:10 PM
Mr. Badwrench
Default Re: D16 turbo, over heating problems. Need some help/advice. (boostedcivicsir)
if you keep driving like that, youll burn exh valves too.
Old Aug 20, 2007 | 02:15 PM
Jwbetley's Avatar
The engine is rebuilt. I have a new cometic head gasket. I have not been driving the car. I do not have the stock manifold. I just feel that the temperature should not be that high, even with a bad turbo.
Old Aug 20, 2007 | 02:16 PM
Mr. Badwrench
if you have no oil goin to the turbo, and it is bolted to the manifold, it is probably not turning, causing a massive restriction. if the exh cant get out it will overheat.
Old Aug 20, 2007 | 02:50 PM
ryan89crx's Avatar
haha, turbo is definitely garbage now.
think about how fast that chra is spinning because it cant create pressure which will cause resistance. now think about how fast it is spinning with NO LUBE
entertaining
mike93eh
Apr 6, 2005 03:59 PM
CrazyModGSR
Aug 19, 2004 07:45 PM
Blindstuff
Jun 2, 2004 09:51 AM
SolidSpruce
May 13, 2003 12:00 PM
NosajCivic
Apr 27, 2003 01:45 PM
