d15vs d16?
Old Aug 10, 2010 | 08:27 PM
2kdrift's Avatar
Default d15vs d16?
what block should i boost a d15b7 or a d16z6?
either way i am using a y8 head
what will the differences be??
its about 7lbs.................
Old Aug 11, 2010 | 02:28 AM
Nichelson_Performance's Avatar
Default Re: d15vs d16?
use a z6, it's a way better block/bottom end than the d15 will ever hope to be. also the y8 head works great to a certain point but the z6 head outflows it considerably and will make more power easier
Old Aug 11, 2010 | 03:25 AM
2kdrift's Avatar
okay thanks...i wasnt sure becouse the d15 will actually be higher compression and would be better for low boost?
but yeaah i know the z6 is beast....and know about the z6 head also but i did port the y8
Old Aug 11, 2010 | 04:50 AM
kyden's Avatar
always go for the higher displacement.
Old Aug 11, 2010 | 05:41 AM
The y8 will do fine, but the z6 head will still outflow a ported y8 head cause of the type of ports
kamakaze1
Apr 15, 2007 07:35 PM
turbochargeb18c
Sep 29, 2006 08:27 PM
dohdoh420
13
Oct 27, 2005 12:33 PM
eg4usdm
May 2, 2005 07:47 PM
SOHC_MShue
Jun 1, 2003 12:30 PM
