D15 Turbo questions...?
Old Oct 29, 2003 | 03:54 AM
murena's Avatar
Default D15 Turbo questions...?
Hi...
I'm building up a Euro D15b2 engine with sohc vtec head and t3/t4 turbo. I want to know, if somebody has experiences with a project like mine ?
Are ther better roads and pistons avaible for the d15 engine ?
I'm not trying to build up a "boost-beast", just for fun with a little more than 150hp - daily driven car
Greetings Florian
Old Oct 30, 2003 | 11:56 AM
murena's Avatar
Default Re: D15 Turbo questions...? (Ed3ler)
Nobody here with boosted D15 engines...
No impressions or tips...
Greetings Florian
Old Oct 30, 2003 | 12:04 PM
Ben Huynh's Avatar
We've had several customers go the D15 route over the years. PM me if you have questions.
Old Oct 30, 2003 | 12:09 PM
traction issuez's Avatar
Default Re: D15 Turbo questions...? (ben@importparts.com)
https://honda-tech.com/zerothread?id=420823
search up on eg6turbo's archive posts.
Old Oct 30, 2003 | 01:19 PM
b16ahybrid's Avatar
A t3t4 hybrid will be overkill esp if your only shooting for about 150hp...a stait t3 will suit you better, something like the size of a saab t-3 (.48/ .42)
Old Oct 30, 2003 | 06:26 PM
murena's Avatar
Default Re: D15 Turbo questions...? (b16ahybrid)
Hi...
I've a "small" Garrett T3/T4e with 57 trim compressor wheel and 48AR turbine, I think it would work together ok. I would use a light 11,9lbs flywheel and alu under- and overdrive, so the engine should spool up fast and with it the turbo. Other modifications would be until now a postet engine block, rebuild D16z6,...
I don't know which fuel manegement I would take and my biggest question: Which fuel injectors would be the right for this setup ??? I'm looking for a vortech FMU (?)
An Apexi would also be instelled. As fuelpump I would take a modificated Bosch from Porsche 911 ore something like that, they are cheap and easy to get in germany
Has anybody more tips, what I should use on this setup, the car should be on the road again in the beginnig of the next year, so there is a litle time for changes in the setup...
Greetings Florian
Old Oct 30, 2003 | 06:54 PM
Bailhatch's Avatar
I have a T25 on my 1.6 Dseries and it definatly makes over 150 hp. It will spool a lot faster so you make good power from 3500 rpm and up rather than just in the upper rpms. You should get a straingt t3 if 150hp is all you need. If you want more, the turbo you have should be good for 100hp more or so. The T3 would be my choice, sized right between what I have and what you have, perfect
for low boost (under 7-8) the FMU will work fine. Get an adjustable one so you can tune it a little better than just a 12:1 or whatever. If you are going the use the FMU you need a high pressure in-line pump rather than the high volume in-tank porsche or walboro etc...
Stock injectors would work fine for 150hp. The AFC hack is also good for low power turbo setups, search for it. The hack can be tuned a little better than the FMU and runs stock fuel pressure. All I have is 450s and the SAFC, no pump (yet) drives great!!!
light fly wheel is good, you could even go lighter (I like the ACT Xact forged chromoly ones) skip the pulleys, they are a waste of money and can compromise the reliability of the crank bearings because they have no harmonic balancer.
Are you going to add an intercooler? what octane is your petrol (hehe is that right?)
Old Oct 30, 2003 | 09:01 PM
PHiZ's Avatar
Default Re: D15 Turbo questions...? (Bailhatch)
Uberdata is very good, and can be cheap. It is much like any other laptop editor. Much better than the AFC or FMU.
-PHiZ
Old Oct 31, 2003 | 05:30 AM
murena's Avatar
Hi...
our fuel is avaible from diesel to 100 octane fuel But the 100 octane is more expensive than gold here, so it would be around 97...98 octane
An fuel pressure regulator I have still... good to know, that it works in the beginnig...
I think the 150hp are just the beginnig - I think all off you know: First boostet car and you would everytime more
But I'm not sure, if the block can handle much more hp... the only modification until now would be the posted block... everything else is oem (but in very good condition)
Old Oct 31, 2003 | 05:37 AM
Joseph Davis's Avatar
You will waste your time posting your block. Stock sleeves are weak and like to swell, and when they have nowhere to swell to they crack at right angles to the post.
For low boost, and your power goals, your one and only worry is your rods. I still know a lot of D15 guys making 150-170 on stock rods without a problem. You should be fine.
Boricuanology
Sep 20, 2006 07:49 AM
Kelly.
Dec 27, 2005 11:48 PM
Ivan
Jul 17, 2002 06:40 AM
InfamousRS
Dec 11, 2001 08:57 PM
Sohc Driver
10
Nov 8, 2001 12:48 PM
