D series turbo project
Old Feb 22, 2006 | 04:04 PM
tommy.'s Avatar
Default DSM INJECTORS??
would these injectors be a good size for a d series turbo setup?450??and would 1g dsm injectors fit without modification?
Modified by eg6b0i at 5:19 PM 2/22/2006
Old Feb 22, 2006 | 04:33 PM
beerbongskickass's Avatar
Default Re: DSM INJECTORS?? (eg6b0i)
I have been running them for 2 years (2g DSM 450's) and they work great. Lots of other people run those injectors as well. I had to grind out my o-rings a bit to get them to fit, but sometimes they will slide right in with a little lube.
Old Feb 22, 2006 | 06:33 PM
Tippyman's Avatar
Default Re: DSM INJECTORS?? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote"> but sometimes they will slide right in with a little lube.</TD></TR></TABLE>
That's always worked for me!
Sorry, it's late and I had to...
Old Feb 22, 2006 | 06:35 PM
Adam.C's Avatar
1g or 2g dsm injectors are great for turbo d. just get sone inline resistors or pack. what are HP goals?
Old Feb 22, 2006 | 06:48 PM
nonvtecD's Avatar
Yeah, boring them out works best then they fit nice and snug, just make sure that you use a resistor box like they said.
Old Feb 22, 2006 | 06:53 PM
turboeg77's Avatar
Default Re: (nonvtecD)
would 450's be enough for 320ish whp.
Old Feb 22, 2006 | 07:22 PM
Default Re: (turboeg77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg77 &raquo;</TD></TR><TR><TD CLASS="quote">would 450's be enough for 320ish whp.</TD></TR></TABLE>
You could get about that if you up the fuel pressure to 50psi. At the stock 42psi DSM 450's max out at about 300whp.
Old Feb 22, 2006 | 07:29 PM
turboeg77's Avatar
Default Re: (beerbongskickass)
thanks for the info looks like ill be getting some 750's soon
Old Feb 22, 2006 | 08:52 PM
Civicman86's Avatar
may I add they only drop in with no modification if its on an OBDI motor. OBDII motors such as the y8 in the 96+, the clips will not work and you have to get obdI clips.
Might help somoene that is searching for answers. I never knew that fact until it was to late and spent 30 mins trying to figure out WTF the clip would not go on, when I read countless times on the internet that it should work.
Cheers
Old Feb 22, 2006 | 09:11 PM
USDM 4G VTEC's Avatar
http://www.witchhunter.com/injectorcalc1.htm
Old Feb 23, 2006 | 04:37 AM
blackeg's Avatar
. At the stock 42psi DSM 450's max out at about 300whp.</TD></TR></TABLE>
oh i know all about that first hand. trust me you dont wanna max them out.
but i have used rc's, dsm's, correct injects and precisions now, but the dsm's have never given me a problem
Old Feb 23, 2006 | 05:14 AM
splitime's Avatar
Default Re: (blackeg)
Another nice thing with the DSM injectors... when you want to go bigger... there are alot of used bigger injectors floating around from dsm people... Usually quite a bit cheaper than anything for Honda's.
Even simple steps like going to a 560 are easy... just put in a set of evoVIII injectors instead.
Old Feb 23, 2006 | 06:08 AM
slotec's Avatar
Default Re: (splitime)
yea just get some dsm injector clips from any dsm NA or turbo for the injectors, i tried to clip my obd1 eg clips onto the injectors and it didnt work so i had to get the dsm clips and a resistor box
Old Feb 23, 2006 | 09:11 AM
JDM_Risa's Avatar
Default Re: (slotec)
you can even use your stock injector clip with slight modification on the inside there a inner groove just shave it down or trim it down and your set along with a resistor box
these injector are great for a budget boost...they are fairly cheap and easily to come by
Old Feb 23, 2006 | 11:05 AM
tommy.'s Avatar
thankz for all the comments
Touge_EF
May 24, 2006 03:12 PM
LisaCivic
May 10, 2005 10:56 AM
camelian
Jun 18, 2004 09:14 AM
hb_racer
May 25, 2002 10:47 AM
