D series T3 manifold options?
What are all the possible options out there?
So far this is what information I have....
-Revhard : very expensive for just a cast style mani.
-Drag: yet another cast manifold
-MaxRev : good steel mani, but still in the production phase.
Does anyone know of any other manifolds out there for the D series?
I am looking for a nice steel manifold that is able to mount a huge T3/T4 within the tiny space of a CRX bay, and also has to utilize a 35mm wastegate flange.
Does anyone have pics of these Manifolds just for comparrison?
Thanks for any information!
Re: D series T3 manifold options? (Bryson)
I took am looking for the following info on a good manifold for D-series, (d16y8 here)
I know Sfp makes d-series manifolds also. http://www.sfp.net/
i have ahd 1 request for an equal length, but i doubt there is much if any of a market for the d series full-race manifolds. am i correct in assuming so?
Re: D series T3 manifold options? (FFgeoff)
Yes you are....because all us D series guys have to have that saftey cushion of "it's just my daily driver" if we loose, cause we wouldn't want to say "yeah, you beat me even though i have the full race equal length manifold"
Unfortunetly there isn't
I am one of the few on the quest for a high HP D series....
IMO, its a better project then building ANY B series engine.
I like the challenge.
I am not neccisarily looking for a Equal Length mani, but just one that is reliable, inexpensive( ), and mounts the turbo in a good place.
Bryson:
Be careful if you get something that is SS Tubular. The D16A1/ZC have the same exhaust manifold bolt pattern (to the head) as all of the other D series engines, but the exhaust ports are positioned slightly different in the head (they're down about 8mm or so). On a cast manifold, it's no problem since you can just grind away.
Let us know what you find.
Sonny
Sonny
Re: D series T3 manifold options? (Sonny)
I'm probubly going to go with a custom SS mani....
I will get the D16 flange and port match it too the head....
This will also allow me too position the turbo more to my liking.
I will try to make a turbo support, so the manifold is less likely to crack.
crosser11
08-22-2012 06:46 PM
Ri5e
05-04-2003 09:33 PM
