D-Series Build Question
Old Dec 9, 2007 | 01:12 PM
bimmeracer's Avatar
Default D-Series Build Question
Whats the max WHP that can be attained with a d16 vtec with a thicker HG and studs? I know someone on here is running a little over 300 with the greddy hg, but I am not sure if that is realistic for everyone.
My next question is, what size thickness is recommmended for this motor with boost?
Old Dec 9, 2007 | 01:26 PM
Schister66's Avatar
Man U FTW
people have made ~400whp, but the general consensus is that if you want it to be a reliable DD, 220-240whp seems to be the cutoff. If you want more, an Eagle/Vitara build is rather inexpensive
Old Dec 9, 2007 | 06:09 PM
bimmeracer's Avatar
Thanks
how much does it typically cost for an eagle/vitara build and how much whp can that setup hold?
is this considered the best deal?
http://cgi.ebay.com/ebaymotors...ZWDVW
We are trying to get over 300whp, and its not a DD, just a side project.
Also, do anyone have any suggestion on the HG?
Im pretty sure if i do the eagle/vitara build, I would be better of with the stock HG and Arp bolts, but what is a good HG for a stock engine internally to lower compression?
Lastly, should I go with a t3/t4 or a GT28/30 for a over 300whp build?
Old Dec 9, 2007 | 06:15 PM
Tippyman's Avatar
Default Re: (bimmeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer &raquo;</TD></TR><TR><TD CLASS="quote"> but what is a good HG for a stock engine internally to lower compression?</TD></TR></TABLE>
I think Cometic makes thicker HG's that will lower comp. I would just stick with the OEM Z6 gasket though. You will definitely have to get the motor tuned regardless of what you do, and the tuner can compensate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer &raquo;</TD></TR><TR><TD CLASS="quote">Lastly, should I go with a t3/t4 or a GT28/30 for a over 300whp build?</TD></TR></TABLE>
How baller are you?
Old Dec 9, 2007 | 06:33 PM
bimmeracer's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
How baller are you?</TD></TR></TABLE>
This is actually for my friend. He is looking to spend about $1-2K. The car came with a t25 turbo, but the manifold is cracked, so he wants to upgrade to a T3 manifold. we trying to get into thw 3-400whp range. whats the best setup?
also, should he go with 750cc-or 1000cc injectors for that range?
last, are RC injectors the only injectors that will fit?
Old Dec 9, 2007 | 06:39 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer &raquo;</TD></TR><TR><TD CLASS="quote">we trying to get into thw 3-400whp range. whats the best setup?
First off, 300-400 is a HUGE range.
Secondly, "what is the best setup" is a very open ended question. Obviously, he is going to have to buy used parts, and peice together a kit to get it for 2k. Do your research, and figure out what parts best serve what you want to accomplish.
Old Dec 9, 2007 | 06:45 PM
bimmeracer's Avatar
thanks. I am doing reasearch, but its hard to search for "D series" "SOHC turbo", etc.
Basically anything over 300whp is the goal.
If I was to find a gt28 for a good deal, should I look for one with internal or external wastegate? whats better?
I think we will probably go with the t3/t4, if we cant find one in good condition for under $500..
Old Dec 9, 2007 | 06:54 PM
Tippyman's Avatar
http://www.turbod16.com
A simple t3/t4, eagle/vitara setup will get you 300.
Old Dec 10, 2007 | 12:22 AM
bimmeracer's Avatar
thanks for the site.
Old Dec 10, 2007 | 04:57 AM
Autoworks's Avatar
Check http://www.d-series.org as well.
Stock HG
T3/T4 50 trim .63 A/R
jamelin
Jun 4, 2009 07:10 PM
JDMSocal89
Mar 18, 2008 12:00 PM
eastbay92cx
Aug 4, 2007 09:11 AM
FkingSUV
Sep 1, 2004 02:03 PM
maximedx
Mar 10, 2002 01:16 PM
