Cylinder 1 gets hotter ?
Old Jun 6, 2011 | 11:36 PM
alperx's Avatar
Default Cylinder 1 gets hotter ?
Hi friends..
I think the first cylinder (darker colored axhaust manifold pipe) gets hotter than the others. Why can it be ? Injector problem ? ort can be anything else ?
Thanks..
Old Jun 7, 2011 | 06:45 AM
MR.johnson's Avatar
Default Re: Cylinder 1 gets hotter ?
It's cyl. 4 and get a temp gun or egt gauge to check.
Old Jun 7, 2011 | 11:36 AM
turbohatch96y7's Avatar
Does your car smoke it could be burning oil in that cylinder
Old Jun 7, 2011 | 11:43 AM
BigMike0147's Avatar
Yeah, what this guy said...
Old Jun 7, 2011 | 01:00 PM
alperx's Avatar
no I dont have any smoke..
by the way.. I can't drill the manifold.. isn't there any other way ?
and I dont think anyone in here (a small town in Turkey) have a temp gun..
I thought of taking out the injectors off and take them to the test.
so that if the hot cylinder's injector is not working well and if that cylinder is leaning out,
maybe that's the problem ..can it be ?
Old Jun 7, 2011 | 01:17 PM
carrollea's Avatar
switch injector 4 with 1 and see is the manifold colour will change.
if you can get turbos, manifolds, intercoolers,ecu and maps then you can get a temp gun.
Old Jun 7, 2011 | 01:40 PM
alperx's Avatar
I thought it's expensive..sorry..
Old Jun 14, 2011 | 11:33 AM
th3pwn3r's Avatar
I believe you can get a temp gun for $100. Did you try swapping the injectors as someone mentioned?
Old Jun 14, 2011 | 12:42 PM
Turbo-LS's Avatar
cylinder 4 usually runs the hottest i believe but shouldnt be that much hotter
Old Jun 14, 2011 | 03:08 PM
extralargenog's Avatar
cyl 3 runs the hottest. You are wrong ;O)
Old Jun 14, 2011 | 04:18 PM
How long has the manifold been on the car
Old Jun 14, 2011 | 05:32 PM
vwbased's Avatar
have a nice day
Old Jun 14, 2011 | 07:27 PM
Originally Posted by vwbased
Cylinder 4, which is closest to the TB, tends to get more air and so runs leaner and hotter. I found on my engine that cylinder 4 required 14 percent more fuel than cylinder 1 to obtain the same lambda reading from the WBO2 gauge.
My setup and a relevant discussion is depicted here: http://www.flickr.com/photos/45424931@N05/5726491309/
ughhh no, 3 does. sorry.
Old Jun 17, 2011 | 10:44 AM
vwbased's Avatar
have a nice day
Old Jun 17, 2011 | 11:06 AM
I understand perfectly well. I also understand that EGT probes are "usually" in 3 for a reason too ;O), not to mention why....
Old Jun 17, 2011 | 12:41 PM
nonvtecD's Avatar
Alperx, do you have an EMS that can adjust individual fuel trims? How has the car been tuned?
Old Jun 17, 2011 | 12:51 PM
MR.johnson's Avatar
why i have my egt in 3 Not 4, he right guys.
you could have a vac leak on that cly. on the IM.
Old Jun 17, 2011 | 06:16 PM
vwbased's Avatar
have a nice day
Old Jun 17, 2011 | 09:22 PM
Then I guess my engine is "special".
No, must be you.
Old Jun 18, 2011 | 06:25 PM
vwbased's Avatar
have a nice day
BoostR41
Engine Management and Tuning
Jul 18, 2009 06:28 PM
213374U
Mar 9, 2009 06:27 PM
.BigSexy
May 19, 2007 10:54 AM
integra_gsr98
Mar 23, 2004 02:50 PM
Ochux
Sep 16, 2001 10:12 PM
