Custom turbo manifold?
Old Mar 27, 2011 | 06:06 PM
bigsnorlax's Avatar
Default Custom turbo manifold?
My friend can lay some nice beads and seems to be a pretty good welder, but the task of custom making a turbo manifold for a F22A is just a bit over our heads.
So i found this site
http://www.trackforged.com/store.php
There arent many options for the F22A's. Just a collection of cast "log" manifolds from i have found. So i thought that i could maybe buy the stainless tubing kit from treadstone and go from there. But the tubing kit is ~$300 i believe and the task is fairly intimidating and if i mess up... there goes my money.
My question is would it be dumb, or just a plain bad idea to buy one of these manifolds and cut them from the flange and weld them onto a F22A stainless exhaust flange? These manifolds look great, and a HECK of a lot more to look at in an engine bay then the log type. Iv heard the logs spool faster... but if im gonna drop the money for a decent setup.. i want it to look pretty as well :D
Old Mar 27, 2011 | 06:11 PM
SQ is the SQUAD's Avatar
Default Re: Custom turbo manifold?
google weirtech he can get u the flanges pretty cheap. acestainless.com can get you all the piping you need. shouldent come up to no where near 300
i believe one of the dsm turbo manifolds will work with a slight knotch cut into the last bolt hole, search for some info on that for an alternative.
Old Mar 27, 2011 | 06:23 PM
bigsnorlax's Avatar
the weirtech site keeps coming up as a malware site and my firewall wont let me, and when i finally bypass it all, the size freezes or the links dont work. Figures .
Do you believe that i could simply modify those other manifolds for my flange? Or are those manifolds garbage?
Old Mar 27, 2011 | 08:21 PM
bigsnorlax's Avatar
bump! Would like to be able to order one tonight (technically morning). Or go an alternate route
Old Mar 28, 2011 | 07:50 AM
h2.4's Avatar
I dont think the f series head has equal exhaust port spacing like most of the others. google what "SQ Squad" recommended on the mitsubishi eclipse turbo manifold conversion before you go modifying something else. Or have one built for the f22.
Old Mar 28, 2011 | 08:34 AM
hondamark35's Avatar
the F22A does have equally spaced ex. ports. the F22B doesn't. i believe the flange for the F22A is the same as the H23. should be able to find one of those pretty easily.
Old Mar 28, 2011 | 08:38 AM
bigsnorlax's Avatar
Well i dont think the spacing would be equal either, but it would be a lot easier to buy those ones, and move them a bit and weld on an extra inch or so of piping then to the flange. And im looking into the t3/t4 so im not looking for a DSM setup.
flangemastermike
May 7, 2006 11:02 PM
Cain Marko
Sep 7, 2004 12:40 PM
jdm91integ
Mar 18, 2004 09:41 PM
99silverbullet
Dec 13, 2003 07:22 PM
Adriano
Dec 25, 2002 10:07 PM
